Question about Maytag MTB2156GES Top Freezer Refrigerator
Ice maker is making ice cubes but won't dump into the tray
    President:
  • 1,891 Answers
Replace the ice maker head . . the heater has failed and will not relace ice .. ,,
Posted on Jul 04, 2010
My ice maker inst working Whirlpoo; model gz25fsrxyy2
By "ice maker isn't working" do you mean it isn't filling with water, it isn't freezing the water in the ice maker, it isn't dumping the ice cubes into the bin, or it isn't dispensing ice cubes?
Was it previously working and it is not working now?
Typically one can hear the valve when it opens to fill the ice maker with water. Can you hear it attempting to do so? If so, and there isn't any water in the ice tray, check that there is water supplied to the valve at the wall and the valve is open. Is there a water filter? Has it been replaced per the manufacturer's recommendation? (Typically, the water filter should be replaced every six months.)
Is the "full" bar pushed up? It shouldn't be. The bar above the ice cubes should not be in the horizontal position. That position tells the ice maker the bin is full so it should wait until the bar goes down, indicating some ice has been used.
Can you hear the bayonet turning? Is the ice maker attempting to dump out cubes whether or not they exist? The next issue after you confirm there is water going into the ice maker that is being frozen and the ice maker knows to dump the ice, is the bayonet. There is a motor that turns the bayonet and a mechanical connection. Either could be at fault.
Jan 22, 2018 | Refrigerators
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
My Whirlpool is not making ice cubes and the tray is dry, no water inside the ice maker but the water dispenser is working fine.
Most likely the water control valve on the rear of the refrigerator is defective on the ice maker side. Fill the ice maker with tap water and if it dumps the ice and does not refill then the water control valve is the reason. Usually an ice maker that still had cubes and will not dump the problem would be the ice maker. Hope that helped you, Thanks, Sea Breeze
Nov 22, 2009 | Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
May 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Maytag MTB2156GES Top Freezer Refrigerator Logo
87 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
