Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Setting I defrosted the freezer today and forgot what setting it should be on the dial goes from 1 to 7
  • 1,557 Answers
4 in winter 5 in summer depending on how often the door is opened per day i would set it at 5 all yr round
Posted on Jul 04, 2010
What is the proper setting on my freezer that has a dial of 1 to 7? My products seem to get iced over.
Sorry to hear about your problem.
Sounds like you have a defrost issue. 5 is a good number, what ever it takes to keep you freezer at zero. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Need correct setting for 30 yr old upright Kenmore freezer
depend on the type of control you have on your box ,,,, best is if it shows 1-7 set it on 3-4 ,, if it has letters set it on C ,,, eather way set the control on mid-point and it will work fine.
Larry
Nov 22, 2008 | Freezers
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Turbo air freezer
Check the time setting on the defrost timer. It may not be set to the correct number of minutes for defrost. Compare it with the side that is working properly for the right time of the cycle.
Jul 25, 2008 | Freezers
Freezer not defrosting between cycles
Check the defrost timer for operation if your unit has one. Some Delfield models have solid state controls. If your system has a timer for the defrost you can open the timer cover and turn the dial in the direction indicated by the arrow until a time peg comes up to the time of day marker. You will hear a loud click and the compressor will shut off. Defrost should take place. The inner dial of the timer will have some indication as to how long in minutes the defrost should take. If the pointer does not move while in the defrost position the timer motor is bad. Turn the dial again so the copper pointer goes past the time of day marker and the compressor should restart. Replace the timer.
Jul 04, 2008 | Delfield 113.28 cu. ft. Commercial Freezer...
Thermostat differential on a Bev air ef48-1as
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
Jun 24, 2008 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Walk-in norlake freezer
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
May 25, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
221 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
