Question about GE 30 in. JP326 Electric Cooktop
We are donating our GE built-in electric cooktop (model JP326) to Goodwill. What do you think is it's value?
  • 8,197 Answers
If you go with the H&R Block deduction pro it will be worth 75.00 for avarage ware up to 105 for like new. This is for the 2009 tax year. I do not know what it will be worth for the 2010 tax year as the taxes might change by then.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jul 05, 2010
How do i wire a ge cooktop
most stoves are 220 and will have four wires(red,black,white and ground). If you only have 3, black to black, ground to ground, red to white
Aug 16, 2012 | GE 30 in. JP326 Electric Cooktop
Voltage for ge jp326 wiring diagram
That's the correct way to hook it up. Check the wires for possible insulation missing.
Jan 04, 2012 | GE 30 in. JP340 Electric Cooktop
Im trying to put the drip pan back under the burners but now the burner wont go down whats wrong?
check the design of the drip pan and make sure it in the same position and shape with the burner before trying to put in back
Jan 19, 2011 | GE 30 in. JP326 Electric Cooktop
I want to replace the drip pans and the cooking elements for GE JP326
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 08, 2010 | GE 30 in. JP326 Electric Cooktop
Defy hob
I take offense at that. I spend my optional time trying to help other people and to give them an alternative to paying a repairman for something that they could do themselves, if they gad a little guidance. Dozens of others are here regularly doing tha same thing...for free. You can get tons of information for free on this site, and you can also directly hire a tech if you need one-on-one assistance. Take a little time to go through this website again; apparently you just hit the wrong button somewhere.
By the way, what is your question?
Respectfully, sort of, Woobie Dog
Sep 13, 2009 | GE 30 in. JP326 Electric Cooktop
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Feb 13, 2009 | GE 30 in. JP326 Electric Cooktop
Burners on JP326 electric not heating
Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
Nov 30, 2008 | GE 30 in. JP326 Electric Cooktop
GE electric cooktop
Try looking at the junction box that it is connected to. Maybe one or more of the wires have burned off or come loose from the wire nuts. How many amps is the breaker? Most electric codes require separate circuits (Breakers) for each appliance. First turn off the breaker. There should be an outlet box of some kind on the wall or behind the cabinet. Follow the wire from the cooktop and see where it goes. Open it up and check if any wires are burnt or loose. If it was installed wrong I would change it. Most cooktops shouldn't be fused at more than 30 amps. Single ovens the same, double ovens up to 45 amps. The problem is if they used an old range outlet with 6 gauge wire and tried to connect both appliances to the same wire. This is hard to do without it coming loose.
Jun 10, 2008 | GE 30 in. JP326 Electric Cooktop
Burner too hot
you set it fro low and goes straigt to high???? no adjustment in heat setting either of or high?? if so youll need to repalce the infinte switch controllins that burner
Mar 11, 2008 | GE 30 in. JP326 Electric Cooktop
Wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Oct 27, 2007 | GE 30 in. JP326 Electric Cooktop
Open Questions:
GE 30 in. JP326 Electric Cooktop Logo
168 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
