Question about Whirlpool GSX9885J Top Load Washer
Board is going thru the cycle ,but washer only fills , no wash, spin,rise,or drain
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
SOURCE: Washer won't spin or drain
I took the easy advice first. One guest said it was the lid switch. So I opened the lid and put a clothespin in the hole and then leaned the lid on it and guess what??? It began to drain and spin perfectly! PHEW... that saved me some time and money till I can get the switch replaced. THANK YOU "guest" from August 11th!!!
Posted on Aug 28, 2008
docjohn174
  • 943 Answers
SOURCE: Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Posted on Sep 11, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Maytag317
  • 1136 Answers
SOURCE: Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Posted on Jul 05, 2009
Washing goes thru fill cycle, and spins, clothes still wet and soap still in machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | GE WBB4500EWW Top Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer fills and runs tru the washing cycle then stops. It won't go thru any other cycles, won't spin and does not make any noise. Is it the timer?
Does it drain?? If not then you need to replace the pump. The pump drains the water hence allowing the spin cycle to engage. Sorry for the bad news.
Oct 17, 2009 | Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Water continuously runs and cycle won't start. The washer tub doesn't seem to be filling with any water.
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
Aug 08, 2009 | GE WVSR1060A Top Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Whirlpool GSX9885J Top Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
