Question about Toshiba 32HL67 32 in. LCD Television
Every time we get a power cut, the tv will not come back on when power resumes. It usually takes a couple of days and fiddling of wires to get it on. is there a sensor or something to press?
    Sergeant:
    Champion:
  • 324 Answers
You need to put it on a surge protector, if not your looking at replacing it, before the power goes out theres usually a surge associated with it, i've fixed too many tvs that people could have saved with a 8 dollar purchase of a surge protector
Posted on Jul 04, 2010
Have a lg 42 that play for about 20 min then cut off may come back on in a couple of days
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 19, 2014 | LG 42PJ350 42 in. TV
A small cut in the cord and would no work. If you straiten the cord the power reaches the tv. however, on the second time straitening the cord the cord let out a bang and a large spark. Now the tv will no...
You would have to know a little about electrical repairs, if you don't then I suggest finding someone who does because the repair can present electrical dangers.
Some might say to splice the cable around the cut, but I'm not one of them. If the power wire comes from the inside of the TV then you can usually open up the back of the TV and replace the wire with a little soldering. Make sure the wire you use is properly rated for a standard house appliances. (lamp/etc.) If the wire instead simply plugs into the back of the TV then you may just have to contact the manufacturer (or electronics store) to get a replacement wire.
Jan 03, 2014 | Panasonic Televison & Video
When I turn on my sister's Acer Aspire One D255 it immediately takes me to the Windows Resume Loader scream and when I choose resume system load it takes me a blue error screen and then back to the...
Hi
if you do not have anything on it that you are desperate to keep you could try the factory
restore option
to do this
power up and press the ALT+F10 key a couple of times
this will hopefully take you into the factory restore option
then follow the on screen instructions
hopefully this will help you
many thanks
Aug 16, 2011 | Acer Aspire One Netbook
Toshiba tv keeps on changing inputs at irreguar times on its own and the every button on the remote changes the input. have tried removing batteries from remote but problem continues
There is a known problem with Toshiba Tvs that options change with out any input of buttons or remote. the tv switch panel needs replacement. This is situated behind where the buttons are on your tv usually bottom right. there is a work round if you dont want the expense of part replacement. you can disconnect these buttons and only use the remote. This requires taking off the back (ensure tv is disconnected from power as there is high voltage in the tv) once the back is removed and tv is laying on its front you will see bottom left where the buttons now are, a couple of cables one will have seveal wires and one will only have a couple of wires take the smaller one off this will disconnect the buttons and stop the problem. once this is done you can only use the remote control to control the tv settings but the power on off button still works.
I hope this was useful.
Apr 05, 2011 | Toshiba REGZA 32AV615 32 in. LCD TV
Hi, I have a 1995 1.6 monomotronic VW POLO (eng code AEA) and the engine cuts off momentarily and resumes normal operation after a sec or two. At the same time the engine rev gauge goes down to zero(not...
Sounds like your on the right track. I would check for loose wire connections around the fuse boxes. Pull any fuse that has to do with the ignition or ECM/PCM, as these do corrode and loose connection. I would not rule out the ignition switch either, as the problem you are having is intermittant and switches are bad for intermittant problems. They heat up and loose contact, and regain contact when they cool down, and usually in a couple of seconds.
Feb 13, 2011 | Volkswagen Polo Cars & Trucks
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
Error code 6502
1-- With the printer unplugged, remove the ink cart to the right ,
2--Plug in the printer ,Press the POWER button, Do not release the POWER button ,and then press the RESUME button twice in succession .Now release the POWER button ,press the RESUME button 4 times .
3--The beeper may sound once ,Then Unplug the printer ,then power back up and reset the printer electronics ,open the printer and this process is finished. I believe this should take care of your issue, it's basically a cold reset for the printer, Give it a shot...
May 11, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Laptop does not power up.
Couple of questions first: -What operating system are you using? -Before when it took a while to resume windows what error messages, if any, did you get?
Feb 04, 2007 | Sony VAIO PCG-K25 Notebook
Toshiba 32HL67 32 in. LCD Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
