Question about ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television
I have a viewsonic LCD TV, N3260w. One day it worded fine & the next day the TV wouldn't even turn on! I've had a friend look at it & he says the circuit board needs to be replaced? Where do I take it to get it fixed? Also,is it worth the parts & labor? I don't know what the TV costs.
  • kelly_zotter Jul 06, 2010
    Thank you. Is fixing the power supply self explanatory or something a professional should install? I appreciate your help!
  • 11,361 Answers
More likely to have failed power supply module.
http://www.shopjimmy.com/catalogsearch/result/?q=N3260W
You can download the spec of the power supply to get the pinout for voltages checking.
http://www.fspgroupusa.com/fsp2283f01/p/641.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 04, 2010
  • Bud Martin
    Bud Martin Jul 06, 2010
    In your case, Iwould suggest to check the voltage output first to see if you do have the 24vdc output. The power supply cost about $100. To have the TV repair, I will estimate repair bill of $200~300 range if they are willing to try to get parts for you. Most shop do not like to install used parts becuase if it failed they will lose money on repair works. Remove and install the new power supply is easy but you have to make sure it is the power supply first.
Viewsonic n3260w will not turn on no green light and I have check the plug ,cord and power at the wall
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | ViewSonic NextVision N3260W 32 in....
I have a Viewsonic N3260w TV, the Power Indicator light is flashing red continually, but the remote wont start the tv, I have changed the batteries, turned the tv on and off, but the tv still wont...
The problem of your tv is in the power supply. In order to find the power supply of your tv ,you should follow the ac cord. But first you should unplug the unit and open the back cover of your tv there you will find the power supply, try to check the capacitors, it is cylindrical shape and has a plastic cover. Try to observed if their is a wet mark or oil mark that spread in to the pcb then replace it. But when replacing the capacitor you should observed the polarity of the capacitor and replace it exactly the way you pulled it out.
Jun 06, 2011 | ViewSonic NextVision N3260W 32 in....
My viewsonic n3260w
You need to find out if it is putting out the 24vdc needed by the backlight inverter board, you may have bad shorted out inverter board that may have taken out the fuse, you need to do some probing.
Power supply pin out: http://www.fspgroupusa.com/images/specs/FSP228-3F01_SPEC.pdf
Power supply: http://www.shopjimmy.com/fsp-fsp228-3f01-power-supply.htm
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please post back what you find.
Jul 21, 2010 | ViewSonic NextVision N3260W 32 in....
I have the above tv viewsonic n3260w and lost the picture but kept the sound any ideas what may have happened
Ur LCD inverter board is dead.This board help to get the backlight to the LCD screen to make the Tuner board get the tv signal throught.Replaced this LCD inverter board will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Apr 26, 2010 | ViewSonic NextVision N3260W 32 in....
Where can i get power supply module for viewsonic lcd tv model N3260w
You can buy power supply board/ module of Viewsonic N3260W from Shop Jimmy on special price, $65 only.
Thanks.
Mar 02, 2010 | Televison & Video
ViewSonic Mod# N3260W VS11436 1M
I do not know the exact value but if you trace out the copper trace from the rectifier output, it should go to the first filter cap and then there will be an inductor and filter cap after that, you can figure out the voltage rating from there. You can get the parts here: http://www.shopjimmy.com/catalogsearch/result/?q=ViewSonic+N3260W
Look here about caps: http://en.wikipedia.org/wiki/Capacitor_plague
Pictures of the power supply will help. budmrtn@aol.com
Dec 08, 2009 | ViewSonic NextVision N3260W 32 in....
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Logo
530 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
