Question about GE Profile JGP636 Gas Cooktop
Electronicstartwillnotshutoff after the propane ge gas cooktop-is turned off the electronic ignition will not shut off --till we shut off the power source ----what to do??/
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Cooktops
GE JGP 945 continues to spark. Removed all igniters but continues to click. Bad Spark Module?
no,its a bad switch on one of the gas valves,they are piggybacked on the gas valve and are supposed to turn on and off as the valve is turned on and off,on has broken and is on all the time even with that valve in the off position,carefully remove each switch from the circuit till it no longer sparks with all the valves in the off position
Mar 30, 2011 | GE Profile JGP636 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
Electronic ignition clicking on cooktop
one of the burner switches has shorted, and needs replacement. Turn the power off to cooktop, and check with VOM if there is any continuity on any of the switches when the y are in the "off" position. Replace the one which has continuity. Some GE cooktops have an assembly of all four switches and harness. Check by model number with any parts distributor.
Mar 03, 2010 | Cooktops
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
GEXL44 burners light with match, but not with electronic ignition
if u push the knob there is a clicking sound, if no the problem is damage the ignition coil, need to replace it,or check the outlet,plug or its batery operatet ignition? replace the batery.
the ignition is power operated,check the power source.
tnx gerbee
Jun 22, 2009 | GE Profile JGP636 Gas Cooktop
Ticking sound from GE cooktop igniter
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
May 25, 2008 | GE 36 in. JGP628 Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
107 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
