Question about LG Flatron W2242P-SF 22" Monitor
How do I adjust the image width on this wide screen? Everything appears distorted and wider than it is. I would like a narrower image.
  • 2,229 Answers
This is one of the problems with the wide aspect screen. Most images seem to fit best on the older monitors.
You can go into the video properties and choose one the the display types that best display your image. Unfortunately, by taking a normal (to us) image that looked just fine on an older monitor and displaying it on a newer, wide-aspect monitor, you're gonna distort the image or crop it in a way you didn't expect.
My advice is to experiment with the display until you find something you can live with.
Posted on Jul 04, 2010
How to adjust placment of twin needle so it doesnt hit edge of bobbin holder?
The needle should not hit the bobbin holder at all. Do you have the needle inserted all the way? If it is too low, it will hit. If you are saying the needle is hitting the sides of the needle plate where the needle goes through, then the needle is too wide for the plate. Either use a narrower twin needle or see is a needle plate with a wider needle hole came with your machine. Some decorative stitches can't be used with a twin needle because the combination of width of stitches and width of needle is too wide. In that case, narrow the stitch width until the needle doesn't hit the needle plate or use a narrower twin needle. I hope I have helped and answered some of your questions. Good luck.
Apr 26, 2014 | PfaFF Sewing Machines
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
Printing files smaller than actual?
Because the 5500 does not print to the edge of the paper it will auto shrink the image to fit the paper ( a 36 inch wide image will shrink to 35.45" when 36" paper is used). Your image will need to be at least 0.55" narrower than the width of your paper to avoid this. so: Crop the image if you can, or use wider stock.
Feb 03, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
I can't narrow the serged edge width to do a narrow rolled edge
There are 3 things that come to mind for me.  I should say that I have a Bernina 1300DC, so your machine may not have the same parts, but check these things.  First, are you using 3 threads?  If so, is your needle in the narrowest setting, in the right hand hole closest to the body of the serger? Secondly, is your rolled edge lever retracted?  This lever is attached to a wide tooth that holds the width of the seam in place.  It is under the presser foot, between the loopers, and should retracted so that the stitches are allowed to become narrow.  If your machine doesn't have this lever, don't worry, you can also try a third thing.  Adjust your cutting width to a narrow setting.  There should be a knob that moves the upper cutting knife from right to left-- right being a wider seam, leaving more of the fabric intact, and left making a narrower seam that trims off more of the fabric as you sew.
Hope this helps! Elsje
Dec 10, 2008 | White Sewing Speedylock 1600 Mechanical...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Acer 19167W flat screen
Depending on the application you are viewing the picture in you can shrink the application window. You could reduce the size of the viewable area but that defeats the purpose of the wide screen which is to provide a better viewing experience (to quote the marketing types). It sounds like....since the wider screen really has nothing to do with your picture size....you might want to adjust your picture size independent of screens and applications. There are a variety of free products out there that can do this...and some are really nifty...perhaps better than the software you might now be using.
Aug 02, 2007 | Acer AL1916W 19" LCD Monitor
Image width instability
on the pc, choose a 640x480 vga screen...if ok, then gradually build higher res screens from there
May 27, 2007 | LG Flatron 915FT Plus (White) 19" CRT...
LG Flatron W2242P-SF 22" Monitor Logo
380 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
