Question about LG WM1814CW Front Load Washer
Our LG wm2688 washer is leaking from the top rear left portion of the washer
  • blh10 Jul 04, 2010
    Thanks works after replacing a hose.
    Brigadier General:
  • 3,917 Answers
Hi
Looking at top cover from rear of the washer---there are two white plastic tabs with 4 Phillips screws. Remove only the bottom 2 screws--one from each side--and leave the remaining top screws attached.
Grasp the top cover of the washer at one corner with both hands and squeeze towards the rear--some are fairly tight but it will slide rearward. Wipe all dust from the top for a better grip. Wearing rubber coated gloves helps too. After the top moves back about two or three inches--lift up to remove.
The door gasket can be inspected from the front with a good flashlight. I run my fingers full circle to feel for holes or tears.
The area of the leak is near the drain motor/pump assembly. Make sure that the pump strainer is tightly closed---but not overly tight---it has an o-ring seal. On a few older LG washers---the drain hose may have a perforation from vibration. This not very common but I will come across this one or twice a year.
After removing the top cover---look for any obvious origin of the leak during a test cycle. If it's possible--remove the back service panel and look toward the drain pump area for water leakage. Use care not to touch the spinning motor unit--try to observe from a distance with a bright light.
This type of small leak is due to incorrect type of detergent or too much of the correct/HE detergent. This can cause suds to ooze out of the rear tub air vent. Later the suds revert back to full liquid and the water can be seen at the front of the washer if the floor has a slight slope.
Correct use is as follows:
HE: (2) Tablespoons Per Washload
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
You can also check the link given bellow to haver a detailed view about the problem when your washer leaks….
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itleaks
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 04, 2010
I have LG washer model#WM2140CW leaking water underneath when I turn the washer on
take top off(two screws on back, then slide top back about 3 inches and left up and off), start wash and take a look inside, you can see most of the hoses from there.
Sep 13, 2015 | LG WM2140CW Washer
Lg wm2688 drum light won't turn off
its happerning some time after used dry option,,,becouse this iscondensation dry systterm,,all the humidity become water power connetion getting wet,, afetr some time its will gose off....
Apr 13, 2014 | LG WM-2277HW Front Load Washer
I have taken apart my drain pump but now i can't remember where the wires go on a lg front load washer
There are two connectors that attach to your drain pump, a black and a brown. They attach to the metal contact on the pump, it doesn't matter which one goes where, they are interchangeable.
When you put the front panel on, there is a door switch connector you need to attach before you put the screws back to hold it in place. After, the connectors on as you attach the top display portion of the washer. They are color coded, put the back into where the connector match with the size and colors on the main board.
Afterward, you can put everything back together and test the washer. Everything should light up and turn back on as normal before. Do not forget to put the particle filter trap back into the pump after everything is together on the bottom left corner of the washer or else it will leak lots of water when you do a wash.
Mar 19, 2011 | LG WM-2277HW Front Load Washer
I've got a leak in my LG WM2277HW coming from the valve inlet (I believe part 5221ER1003A. Anyone else experience this issue? Seems like I can simple replace the part? Thanks!
Yes, I've had this and had to replace the valve assembly, fairly easily fixed once you get the part, and after you discover that the top of the Washer comes off by unscrewing and removing the screws and hinges at the rear top of the Washer and then sliding the top back, away from the front (I had to jar it fairly hard). I hope this helps.
Aug 14, 2010 | LG WM-2277HW Front Load Washer
How do you open washer to get to inside cold water connection to fix leak? where are screws for top cover?
They are under the top cover at the rear of the machine, unscrew and slide the cover back about 20 mm and it will come off.
Apr 17, 2010 | LG WM1815CS Front Load Washer
TE error code on my LG WM2688 washer. Thought I started cycle, went downstairs. Checked back and noticed it never started and had a tE error code on screen. Manual says, unplug and call for service. ...
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 29, 2009 | Washing Machines
Water leak from the top rear inside
You do need to; probably one of the pipes has come loose, can be re-fitted or replaced if broken.. Simple fix.
Mar 16, 2009 | LG WM1814CW Front Load Washer
Water leak upon filling at top/cabinet joint
Raise the washer top and inspect the water fill tube and the water level air hose.
You will need to set the timer to fill while you are watching for the water leak.
Feb 23, 2009 | Maytag SAV2555A Top Load Washer
CLOTHES WASHER
ck lid switch on new models left rear under top also might try tightening hinge screws left side may even need to adjust lid hinge left side underneath top push back on lower portion slightly this will help it to engage switch better
Jun 01, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
LG WM1814CW Front Load Washer Logo
122 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
