Question about Microsoft Xbox 360 Console
My xbox will play cd's but not dvd's or games.. And it will keep reading and reading but if u listen u can tell the disc isn't turning and idk what to do
    Sergeant:
    Champion:
  • 297 Answers
The good thing about this error is the fact that it is NOT your dvd drive you just need to stop the heat at the back of the drive. Use a good guide or send it in for a fix.
Posted on Jul 04, 2010
Why wont my Xbox 360 play any games but will play DVD videos?
My boyfriend was having the exact same problem. He was able to use it as a media server, but, no games would play at all. Turns out that the disc drive is broken. It isn't reading discs at all.
Mar 25, 2012 | Microsoft Video Game Consoles & Games
Xbox wont read any of our games, but the games will read on friends. We can listen to music or use our microsoft points to watch movies.
Sounds like an issue with the optical drive. I would suggest trying a different type of disc in the drive ( I think they can play music CD's as well as DVD discs). You might just need a replacement drive for it.
Dec 05, 2010 | Microsoft Xbox 360 Console
I think my lens is weak, the cd has to be ejected and inserted a couple of times before it works
Like any system, Xbox consoles require occasional cleaning to remain in peak condition. If you're experiencing skipping, poor sound quality, increased loading time, or any number of technical annoyances, simply cleaning your Xbox lens may correct the problem. The lens is responsible for reading all the data on your Xbox game discs; it is the most important part of the entire system. Cleaning the lens takes only a few minutes with the right cleaning product and know-how.
Difficulty: Easy
Instructions
Things You'll Need:
* CD lens cleaning disc
1.Purchase a CD lens cleaning disc. It is important that you buy a lens cleaner for a CD player, not a DVD player. Classic Xbox consoles are not DVD compatible, but they can play CDs. Some lens cleaning discs are marketed specifically as Xbox 360 cleaners, but these may not work in an original Xbox if the disc is DVD-formatted.
2.Turn on your television and Xbox just like you normally would to play a video game.
3.Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
4.Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
5.Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
6.Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
7.Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console
Aug 19, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
The xbox 360 will not read game discs or give me the option to play the game it only gives me the option to play a cd
Hi
By the problem you have described, i beleive you have a modded Xbox 360 used to play copied games, if yes you need to check what game are you playing.
If it is a latest game, then you would require a Wave 4 patch to play copied games on a modded Xbox 360, you can google on the web to find out the list of games that require wave 4 patch to run before you play the game on Xbox 360
What you need to do is first burn the Wave 4 patch on a Dual Layer DVD and load the game disc first and you would see "play CD" option, now take out the game disc and enter the Wave 4 patch disc you just burned and again you would see "play CD" option.
DO NOT PLAY the CD, just take it out again and re-insert your copied game CD in your Xbox 360 and you should be good to go.
Regards
KreativeGeek
http://gamingbox.wordpress.com
Feb 27, 2010 | Microsoft Xbox 360 Console
My xbox 360 wont play discs - keeps repeating open tray, I can play demos and xbox live but not discs or movies, any tips?? Thanks!
I just found a post on this and it worked for me. My warranty is past. So I took matters in my own hands. I took it apart which was fairly simple cleaned the lens and surrounding areas but it didn't work. But this is what I found out its not reading the disk because the disk isn't spinning. With the box apart and drive open I put it back in the system and turned on the power I noticed the drive would spin slowly I then while the disk was trying to load I spun the disk by hand to help it along and wala it started spinning I powered down put it back together and as of 10:45 2night my gaming nightmare is over. I hope this was helpful. Good luck all!!
Jul 14, 2009 | Microsoft Xbox 360 Console
My game wont read on my xbox 360
I believe you can use a DVD cleaner without voiding your warrenty. If you have a warrenty then call Xbox tech support to get it fixed. And if you don't buy an extended warrenty for $50 and then call them and tell them you need your Xbox fixed
steps to be followed.
  1. step 1 Purchase a DVD lens cleaning disc.
  2. Step 2 Turn on your television and Xbox just like you normally would to play a video game.
  3. Step 3 Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
  4. Step 4 Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
  5. Step 5 Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
  6. Step 6 Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
  7. Step 7 Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console.
Jun 13, 2009 | Microsoft Xbox 360 Console
Xbox says play DvD when there is a game in the Disc drive....
Hi. You need flash the firmware from the old drive to the new drive.
Jun 11, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
May 29, 2009 | Microsoft Xbox 360 Console
Inserted disc press play grinding sound and disc left scrapped
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Dec 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
