Question about Refrigerators
I have a norcold 3163 and will not operate on ac/ dc/ or propane. I have checked all the fuses and power sources what is my next step
    President:
  • 1,561 Answers
first thing you want to check is go to your main power box and check the breaker. You could have a situation where the breaker has popped, and that will terminate power, so you want to go back to that. Make sure that breaker is in the on position. Then the second thing to check on your power; to make make sure that your power cord hasn't come loose from the outlet behind the refrigerator.
Take care.
Posted on Jul 12, 2010
What is issue with my Norcold N3150 not cooling on AC with fault code8?
The "new" refrigerator could have been damaged/defective when you bought it. After all, that door got dented somehow. This should be resolved among you, the seller, and eBay.
Jul 06, 2016 | Refrigerators
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
After the AC plug is plugged in nothing happens? I have not installed propane yet. There is nothing on the display panel. Nothing happens. I checked the AC circuit and there is power there but when its...
That model requires a 12V source to operate the control board. So you must ensure that 12V is hooked up. I am thinking that is your problem. ArctiCold Refrigeration We keep it cold Please feel free to give us a call toll free anytime 1-888-782-6665
Sep 29, 2013 | Thetford Norcold N510U 2-Way Refrigerator...
Norcold 3163 Fridge
There is a 3 amp.fuse in the wiring behind the control panel or somewhere between the control panel and the terminal block. If the fuse is blown do not replace with any higher amperage rating more than 3 amps. Here is a Norcold 3163 Service Manual On page 10 of the service manual shows all of the components that the ac power goes through. Let me know what you find and I will be here to answer any questions you may have, Thanks Sea Breeze
May 08, 2013 | Refrigerators
How to use
Voltage testers and volt meters are two different things. A meter will provide a an indication of the exact voltage and type AC or DC. A tester on the other hand simply provides an indication of presence of power with little to no indication of how much or type.
AC power is what is provided by most power companies in the world. DC is a type of power provided by batteries and DC power supplies. If your tester or meter has provisions to check for AC and DC, you should check for BOTH. If AC power is present and you are have set your meter to test for DC power, your meter will indicate 0 volts. You can see this can be a dangerous condition. Most simple testers will not care if AC or DC power is being tested and the types that use neon lamps will usually glow differently for AC and DC power.
When setting up for testing voltage, you must test across the power source (or in "parallel") or load (such as a light bulb), as opposed to "in series" with the power source. Across would be from the + to - post of a battery, into the slots of an outlet, etc. "In series" is when the tester would be completing a circuit - such as testing across an open switch.
First, check the meter's operation by testing a known good power source by following the next steps. Set the meter for the type power to be tested. Choose AC if unsure. Next, set the meter for the highest voltage range supported. Make sure this range is higher than the expected voltage, otherwise damage to the meter may result. Connect the probes to the power source. Read the meter. If the meter moved only slightly, adjust the range of the meter to the next lower value. You can keep adjusting downward as needed to get the most precise reading possible - but do not set the range to a value less than the voltage present. A 0-300 volt scale is the lowest to measure a 240 volt outlet - switching to a 0 - 150 volt scale will damage the meter. The 0 - 150 volt scale would be fine for measuring 120 volt outlets.
If the meter did not move, change the type from AC to DC. and repeat. If it still does not work, the meter is not working correctly (if testing a know good source) or there is no power present (if the meter worked on a known good power source).
May 12, 2012 | Measuring Tools & Sensors
Will work on ac but not dc. I checked that it has 12 vdc on the wire leaving the boat fuse panel.
Wiggle element out of sleeve and lift up while wiggling. Once element is out, attach to 12vdc from battery or other source and see if it heats up to touch, if not, replace it. Careful, may get real hot to touch.
May 19, 2010 | Thetford Norcold DE0051 Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
