Question about Zonet ZSR4134WE Wireless Router
IP address problem with my router
I have a modem and a router and the router has an error message of a IP address conflict. The modem is now fixed but I can't get internet access due to wrong IP address.
  • 98 Answers
Call up your ISP. and ask for ipconfig check..
Posted on Jul 04, 2010
I get the error message (Basic) Onhook IP Conflict on my Altigen IP705
IP address conflict occurs when two or more computers on the same LAN network end up with the same IP address. When this occurs, both computers end up not being able to connect to network.There are a few ways in which this problem can be fixed.If it is Static IP request your ISP for a change of IP.If it is a Dynamic IP you can try resetting your modem by switching ON and OFF the modem or open the command prompt and type "ipconfig /release," which dumps the automatic address it had, and then "ipconfig /renew," which gets a new address.To check for the change in IP you can visit http://www.ip-details.com which gives your public IP when you visit the site. IP-Details.com
Jan 15, 2014 | Lands Phones
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
IP Address Errors
It sounds like you may be having IP address conflicts. Many Xbox users have a fixed IP address set in their unit and then have a Port Forwarding done in the router to provide faster play. If you reset the router all this is lost. Then what can happen is that the router will assign a device the reserved IP address of the Xbox. When you turn the Xbox on, then it cannot connect as there is another device already assigned that address. Reconfiguration is required to prevent IP conflicts.
Dec 08, 2013 | Linksys Wireless-G WRT54GS Router...
I have a message that say Ip address conflict, what can I do
THERE IS AN IP ADDRESS CONFLICT WITH ANITHER
Identify the peripheral conflicting with the router and change the network address on one of the two. Their setup programs should give you the possibility to do so. The address should look like: 192.168.2.x
x ranging from 0 to 9
Aug 02, 2009 | NetGear WGT624 Wireless Router
IP address conflicting
Have you checked to see if either computer has a static IP address? that might conflict with the DHCP table.
Jun 27, 2009 | Belkin (F5D7230-4) Router (587009)
Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
Apr 25, 2009 | Motorola Computers & Internet
PLease Help
The router should get the IP address on it's own when connected to a DSL or cable modem. If it's needing an IP address then it should be from the modem. The router can have an issue if the modem and router use the same IP range. Try changing router to 192.168.2.1. This can stop the possible conflict for why it's not getting info on it's own.
Aug 20, 2008 | NetGear WGR614 Wireless Router
Loosing internet IP addreess - conflict
are you on cable modem or dial up
Dec 30, 2007 | Computers & Internet
Wireless internet connection
You haven't specified if the host computer is able to access the internet. Ip Address confict can be one of the reasons why the laptop isnt able to connect and we can have a series of reasons why we have this IP Address conflict - 1) There is no wireless encryption defined. So, we have neighbors connecting to the wireless network causing IP Address conflicts. 2) The laptop is not able to renew the IP Address after the lease expires. This can mostly be resolved by restarting the computer and in certain cases flusing the TCP/IP stack. 3) There is a static IP Address assigned to the laptop in the router's DHCP range which is conflicting with the host computer. I would suggest you may initiate a chat with me or anyone else who has expertise in routers to get this successfully resolved. That would definitely save your time. Good luck
Apr 22, 2007 | HP Pavilion dv8000z Notebook
Zonet ZSR4134WE Wireless Router Logo
154 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
