Question about Dynex DX-E401 Router
Can't find the instructions to hook up second computer, we have two computers and the reason for the dx was to hook both of them up now I find I have no instructions, pls help!
    Brigadier General:
  • 10,406 Answers
Assuming that the router has one 'WAN' (or 'Internet') port, and more than one 'LAN' (or 'Network') port, just connect an Ethernet cable from the 2nd LAN port to the network-port on the second computer.
Both the router and the second computer should auto-configure themselves, giving you an Internet connection, without any fuss.
Posted on Jul 04, 2010
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
When i connect my modem directly to my computer i get internet access. when i connect to my dynex router, i get no access on my computer or xbox
You can go here and download the quick setup guide and manual for your router http://www.dynexproducts.com/products/computers/DX-E402.html which will walk you through the setup.
The most common reason it won't connect is that you must have the router's IP number (the one listed as default IP in the manual) set as the GATEWAY address on your computer network settings and your xbox settings, otherwise they can not talk to the router.
Feb 18, 2011 | Dynex DX-E402 Router
How do you turn on the mouse?
mcdevito75 here, Make sure everything is hooked up, Turn computer on, Press the button under the mouse, and wait 20 seconds, then presss button on the reciever, then presss button under keyboard. You should be hooked up. Hope this hepls.
Aug 10, 2010 | Dynex Wireless Optical Laptop Mouse...
I have a 10/100m router and today for some reason we can not connect to the internet using the router. I can connect if the router is not being used.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Nov 30, 2009 | Dynex 4-Port Ethernet Broadband Router...
For some reason when I hook the Router up I can not get onliine on any computer that I have the router for. I just moved and it worked fine at the last place. But the system light blinks. I forget if that...
Blinking shows activity, Double check how you have it hooked up....If you are using Internet connection sharing you should have your modem hooked throught your pc and your pc hooked to the #1 slot on the router...If you have your router connected to the modem its self make sure that you have it connected to the internet port of the router......If this is all set up properly hit the main reset (little black button on the back of the router) hold it for 30 seconds. Another possibility is firewall conflicts. Get back with me and let me know if this worked out for you...If not there are alternate directions we can take to solve this issue as it can be a number of things
Oct 06, 2009 | Dynex DX-E401 Router
Need drivers software for computer
Hook your USB cable into your camera and computer, then turn camera on and select PC, then go to your desktop and click my computer. Find your E drive and double click. then give it a second and my computer tranfers them automatically. my instructions say after you double click on the E drive, double click on removable disk and locate DCIM folder. double click on DCIM folder to open and then there you go! HOPEFULLY THIS HELPS YOU OUT!
Apr 03, 2009 | Cameras
Playstation 2 not connecting to the internet
the router you are using is not comp with the ps2 try using linksys or belkin
Nov 30, 2008 | Dynex DX-ESW8
Cannot use more than 1 computer with my 5 port router
Start with buying a router. The Dx-ESW5 is a 5-port switch, not a router. http://dynexproducts.com/t-faqs_dx_esw5.aspx
You could make it work, but you'd have to assign IP addresses to each of the machines connected to the Internet. For security and a number of other reasons, it's quicker and easier to just grab a router on sale at your local office supply place for $30 bucks or so.
Carl
Nov 11, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
74 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
