I have a 2002 Chrysler Town & Country withg electric doors and my drivers side rear door is locked open and I can't close it. The motor sounds fine when I press the buttons but it's like it's stuck on something at the bottom
Check the closing mechanism and see if it isnt locked down in the closed position, if it is stick your finger in there and pull it out like it would open while moving the door handle, if thats not the problem, see if there isnt a toy or something stuck in the tracks on the bottom or dirt and leaves on the top
Thanks. It was the wire cable at the bottom of the door - it had slipped out. I removed the small black plastic cover and felt over behind it and found the wire cable was loose. I was then able to "unlock" the door by using a screwdriver to pull back on the lever and it unlocked so that I could move the door and see what was going on.
