Question about Refrigerators
My norcold 3163 LG will not operate it is a ac/ dc/ and propane fridge....thanks tom
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link, to download the manual… if it helps…
http://www.tada-rv.com/scripts/pdfretail/get.php?id=177
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 04, 2010
  • tmadigan Jul 04, 2010
    ok have manual already does not explain problem my frig will not operate on ac/dc/ and propane. it only explains what to do to with each individual componenent.
What is issue with my Norcold N3150 not cooling on AC with fault code8?
The "new" refrigerator could have been damaged/defective when you bought it. After all, that door got dented somehow. This should be resolved among you, the seller, and eBay.
Jul 06, 2016 | Refrigerators
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Norcold 3163 Fridge
There is a 3 amp.fuse in the wiring behind the control panel or somewhere between the control panel and the terminal block. If the fuse is blown do not replace with any higher amperage rating more than 3 amps. Here is a Norcold 3163 Service Manual On page 10 of the service manual shows all of the components that the ac power goes through. Let me know what you find and I will be here to answer any questions you may have, Thanks Sea Breeze
May 08, 2013 | Refrigerators
Norcold Model 6182 Operates on lp ok Replaced ac
click this link http://bryantrv.com/docs2/docs/600.pdf this is the repair guid to your norcold includes the 6100 models on page 25 starts the Dc operation testing as well as a Dc Trouble shooting guide I would suggest you go through this troubleshooting section as it will help you greatly to diagnose what the issue is with your unit. After you complete the tests mentioned if you have any further questions message me back I await your reply Thanks again Rick
Jul 24, 2011 | Refrigerators
I have a Norcold 2 way fridge. The propane will
It is possible that the switch is giving you fits. Easiest way to check is to find where the DC voltage goes to the circuit board. Put a meter across the connections and read the DC voltage.
A poor ground can also cause this as well, and is quite common. Remove the DC connections, and make sure that they are bright and shiny. Also make sure that the connections are tight, both in the wire, as well as any crimp connectors. Check for corrosion on crimp connectors in the sleeves, if possible.
Your 10second problem can also be attributed to another cause as well. The thermocouple electrode assembly is very sensitive to placement in the flame, as well as spacing of each "prong".
If you have a multimeter, also check the "AC" voltage as found on the DC supply. You should not have more than a few hundred millivolts of ripple (noise?) present. Very much more can cause erratic operation as well.
Aug 03, 2009 | Thetford Norcold Compact Refrigerator 1.7...
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold DE704D won't switch to AC
http://www.thetford.com/LinkClick.aspx?fileticket=slRtJeja7H4%3d&tabid=497&mid=1316
This link will help with testing and resolve your problem. Can not resolve without these tests.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Refrigerators
Refrigerators Logo
178 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
