Question about Acer Aspire One PC Notebook
USB Ports Malfunction
Hi i keep getting problems trying to plug in and usb hardwares into my usb ports. For example i plug in my cruzer storage disk 1g and i get a message saying the usb has malfunctioned also my logitech mouse please help me.
  • 4 more comments
  • greekstyle Apr 17, 2008
    Iam just downloading the softwares and i will let you know the results thank you for your time
  • sistemax21 Sep 19, 2008
    My Acer is Aspire 3100, and whenever I plug an external drive, mouse, or anything else in any USB port the computer hangs/freezes. The only way to restart it is powering down by power button (4 secs). OS is WinXP Pro SP3. Thanks for any hint/suggestion.
  • Anonymous Dec 21, 2008
    my usb ports do not work. they claim the usb device is malfunctioning and to get another. this problem persists even after a complete harddrive reformat and vista instal!
  • Anonymous Apr 27, 2009
    I am having the same problem with Vista 32 bit.
  • wolf12107 Apr 27, 2009
    my aspire 5050 is giving me the device malfunctioned message everytime i plug in my flash drive, PDA, cellphone or other device into a USB port. I am running vista home premium 32 bit.
  • Anonymous Mar 26, 2014
    It does no go all the way in.
    Problem Solver:
  • 25 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 19, 2010
  • 1,027 Answers
You didn't say which Operating System you are using. Without knowing the OS, Service Pack,or NorthBridge Chip set, this would be hard to fix.
If the System is XP, XP Pro with SP1 or SP2 I would Suggest Upgrading to SP3 release candidate2.
If the usb is failing or hanging then best thing is to update chip set firmware.
Download everest home, open and run, click on the + sign by motherboard, click on chip set, click on northbridge at top of right column and google chipset updates.
Posted on Apr 17, 2008
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Your new hardware might not work properly error will appears
This error message comes up when you plugged in your USB Flash drive into a lower version of a USB port. Try using another port in your machine, ports that are USB 2.0 compatible and you shouldn't see this error again.
By the way, there are old motherboards which does not have ports for USB 2.0. You might want to check your motherboard user guide and see which ports runs at 2.0. If there is none, I'm afraid that the only way around it is to upgrade into a better motherboard.
Hope this help.
Apr 27, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My iomega 320gb hard drive is just beeping when it's plugged in. I've tried plugging it into other computers, trying different USB ports, uninstalling it from my computer then letting it reinstall...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: for a "no data - no charge" guarantee.
Dec 25, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Hard Disk not detecting?...How to recover data from it...??..Plz help...
Even though it is possible that your USB hard driveis corrupt, but
before you finally conclude, try out these few troubleshooting
First of all, it is possible that the USB port that you are using is a
USB 1.0 port, which has a lower voltage not enough to
power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a
USB 2.0 one (Just keep Checking all the ports one by one in case
you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in
an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy
a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Meanwhile, before you try out the second option, test the drive on
a friend's system, that you are sure has a very good system, with
USB 2.0 port.
If after trying out all these, the USB Drive still doesn't work, then
I'm afraid, the drive might have been bad/spoilt.
Kindly keep me posted about the problem and let me know how it
Hope this helps you out.
Thank you for using Fixya
Oct 07, 2010 | Computers & Internet
I removed U3 stuff from my Cruzer micro 2.0GB; now I get message
I would like to point out that this must be something the u3uninstall utility did to the usb stick. Mine was working at full speed while I had the U3 stuff on there, and stopped working at full speed in both windows 7 and ubuntu 10.04 after I used the tool. Sorry this isn't a solution, but it's additional info. It's strange it makes it seem like the problem is your OS or drivers and not the usb stick itself, or what the u3uninstall utility did to it.
Jan 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Unknown device
Plug it through different USB ports, even a USB Hub, or on a different computer. Sometimes rebooting solves the problem. I suspect it is a USB problem, especially on laptops with a small number of USB ports.
I have given mine up as dead several times, but it always comes back up gain.
Hope it helps.
Sep 16, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Jun 20, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Scandisk Cruzer has loaded but can't be seen in My Computer
1. Download this tool:
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Usb not recognized
if you use it on win 95 or win 98 or vista you need specfic drivers for you usb disk
if you get this on win xp please change the usp ports and use another port to insert the disk one of the ports has to recognise.
if the problem persists the usb port controllor on motherboards needs to be checked for faults or uninstalled drivers ,
if nothing works try a pci to usb internal card and dont forget to loaad drivers . this card has 3 to 6 ports for usb
Jun 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Acer Aspire One  PC Notebook Logo
204 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
