Question about Canon BJC S600 InkJet Printer
Yellow light flashes 7 times - and yet I am counting correctly
  • rowleyruth Jul 04, 2010
    the yellow light is flashing seven times. you tech suggested a www. site i went to and that seemed to solve the problem. then i tried to print something and i got a message that my printer is not hooked up correctly. i turned if off and when i turned it on again, i'm back to ground zero - 7 yellow flashes
    that one might have been solved but now i have to wait overnight to see if the next solution works. i unplugged the printer from the power source as recommended.
    President:
  • 3,278 Answers
Hello.
Your printer may just need to be reset:
Power off the printer, disconnect the power cable from its source (power strip or outlet). Leave the printer unpowered overnight.
That should resolve your issue.
Hope this helps.
Posted on Jul 04, 2010
  • NinaE Jul 04, 2010
    Did my suggestion solve your problem ??
    President:
  • 4,070 Answers
Hi! I believe that your printer needs to be resetted for it to work. I provided you a link on how to perform the reset. Hope this helps and have a good one! Please click here http://www.printersiam.com/data/Canon%20Waste%20Ink%20Tank%20Reset%20Procedures.htm
  • 2 more comments
    i went to the site you recommended and the yellow light is no longer flashing...
    however, now a message comes on that says my printer is not hooked up correctly
    i thought you suggestion fixed the problem - no yellow flashing light - but when i tried to print i got a message that the printer is not hooked up correctly.
    i turned off the printer and when i turned it on again, the yellow light started flashing 7 times
  • dj_relly999
    dj_relly999 Jul 04, 2010
    Alright please try this. do the same procedure again and once the flashing light is gone turn off and unplug the printer from power source. Uninstall the printer driver then reinstall again. A fresh copy of the printer driver can help.
    how do i  uninstall and re-install?
The red light flashes 7 time and the yellow light flashes once
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 22, 2014 | Mitsubishi WD73738 73 in 3D HDTVReady LCD...
When i push the power on button it won"t turn on . the blue power light flashes yellow three times
Google Dell W2600 blink codes. You're tv is doing a self diagnostic and letting you know what's wrong with by flashing the yellow light. Count how many time and if there is a sequence to it, then look it up.
Feb 06, 2011 | Dell W2600 26 in. LCD Television
Yellow light flashes when you take the front panel off
Can you give me the blink code that you see. Count how many times it flashes in a row. It will make short blinks separated by a long blink. Please count these until it repeats and let me know what you have. Also, please post the make and model of your unit and I will be able to help you.
Jan 28, 2011 | Heating & Cooling
The lights are flashing and i cant get the chair to move. What should I do?
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
May 20, 2010 | Jet 3 Ultra Power Chair
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
May 10, 2010 | Invacare Supply Group Invacare Pronto M51...
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Flashing green and yellow lights
You need to count the number of flashes to diagnose the error. Then go here and type error lights in the search box. You';; be able to follow the appropriate code to a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | Canon iP100 Portable Printer
Canon i850 not printing
7 times means your waste ink absorber is full, time to let a shop replace the absorbers and reset the counter to clear the error.
Apr 18, 2009 | Canon i850 InkJet Photo Printer
Canon BJC S600 InkJet Printer Logo
100 people viewed this question
old marine
old marine
