Question about HP Pavilion dv1000 Notebook
My HP Pavalion dv1000 shutsdown automatically after some time
It actually does not shuts down, but goes power off. A couple of sconds before it gets power off, it stops responding to all commands and even mouse freezes and then it gets power off. On touching battery/charger area, it seems pretty hot to touch.
  • 1 more comment
  • waynel48 Apr 27, 2008
    i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
  • ndtaylor Apr 28, 2008
    Have a similar problem, started a few months ago. Computer shuts off while working, usually goes unresponsive 1-2 seconds beforehand. AC adapter wore out (wire near jack connection seemed to be broken) and had to be replaced. Bought a replacement from Kahlon.com, assured it was the correct adapter, but looks to be a generic rated for 18-24 VDC with 19 VDC rated as "typical output." Frequency of unexpected shutoff greatly increased while plugged in to this new adapter, computer feels hot, especially around the AC jack area. Computer rarely shuts off while running on battery power, but as battery life has dropped to around 45 mins., computer usually has to be plugged in.
    Any suggestions?
  • dani93 May 10, 2008
    my pavilion dv1000 has had the mother board replace before one year. Then the fan replaced two months later. Now its the mother board again. HP wont help me. A two year old laptop and its gone.
    Problem Solver:
  • 4 Answers
I had this same problem. I resolved it this way after many attempts. This seems very simple but it worked in my case and does make sense. I finally removed the black plastic trim piece on the back of the laptop that covers the adapter connector and connected the adapter directly to the receptical. I have never had the problem with it intermittently shutting down again. It appears that the trim piece was not allowing the proper connection between the adapter and the motherboard. Mine would usually power off within one minute and the battery would never completly charge. I know this sounds strange but it worked.
Posted on May 04, 2009
    Problem Solver:
  • 10 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Ss_wilk,
I'm beginning to suspect that the issue is heat-related. I've noticed that during the worst bouts of shutting off, and then shutting of quickly after restarting, computer feels hot. The improperly rated AC adapter seems to be adding heat (it is hottest near the AC jack), so this could explain why computer only shuts off while plugged in.
How do I get in to blow the fan clean? I've read it's not too hard to get the keyboard off, is this where I go in?
Thanks
Posted on May 08, 2008
    Sergeant:
  • 324 Answers
One possibility could be the power jack coming loose from the mother board. IIf it is loose, it will need to be resoldered or replaced.
Ron-
I had the same problem. We now periodically use4 compressed air to blow the fuzz out of the fan--the fan is not very powerful in this model. DOn't give up until you get a small wad of stuff (do you have dogs or cats?)
Also, we spent about $20 for a device that sits under the laptop and has fans that run to help it stay cool.
I used to leave the computer on 4/7, but now I shut down when I know I won't be using it for awhile.
Doing these three things keeps our dv 1000 Pavillion running.
Posted on Apr 21, 2008
Hp pavillion zd8000shuts down during boot up not hot
Try the Memory mods, the CMOS battery. You have cleaned the fan and vents, right? May be a component failure, hard to say on a older machine. Take a look at HP support: http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=434660&taskId=110
Jan 08, 2013 | HP Pavilion dv1000 Notebook
Hp dv1000 does not power up
maby the charger is not compatible with your laptop.
Aug 25, 2012 | HP Pavilion dv1000 Notebook
My Intel D945GCCR Motherboard shutsdown automatically after 30 seconds on bios without os
your processes fan is damage please check processes fan and fan heat sing
Apr 22, 2012 | Intel D945GCCR Motherboard
Hey, i have hp pavalion DV 1000 with a 512 mb ram and XP operating system. my laptop was having heat-up problems thus trying to put a 1 gb ram in it . yesterday the display went black ,i actually just...
If the PC boots and the screen stays dim, you probably have a bad LCD inverter or backlight. The inverter is the easier fix of the two, the backlight usually requires some soldering. Unfortunately, it is generally the more complicated solution.
Oct 26, 2009 | HP Pavilion dv1000 Notebook
Push power on button; lites up then goes off
there may be many reason behind this, according to you, its switching circuit is ok. but when u switch it on ,the voltage goes to different circuits but due to short circuit between there path. it giving shut down signal so its shutting down imediatelly. basically this the fault of sort circuit. this may happen due to core voltage short(maximum chances), gmch controllar, south bridge(very less chance). u may try.hope this may helpfull for u to identify ur problems.
Aug 23, 2009 | HP Pavilion dv1000 Notebook
Laptop turns off when charger is plugged in !!
Charger is bad and is not putting out the correct voltage which causes the computer to shut down. Battery probably isn't much good either if it only lasts for one hour. Get new batter and charger. Ebay'ers will help you find one cheap.
Jun 01, 2009 | HP Pavilion dv1000 Notebook
Hp pavalion tx2170ee tablet laptop tablet not working
To solve Hp pavalion tx2170ee tablet laptop not working we have hp tablet support phone number +1-800-281-3707 Chances are pretty high that your problem would be resolved over the phone itself It's excellent. 1 800 281 3707 HP Tablet Support Phone Number HP Tablet Repair
Apr 20, 2017 | WalkAbout (37429123225)
Keep shuting down.
reinstall the oerating system...................this will help.......................Sameeraryan
Jan 13, 2009 | HP Pavilion dv1000 Notebook
HP pavilion dv1000 is not compatable with ATT woreless in the home. The computer if in range will shut down and reboot continually. Works with other wireless systems.
uninstall the software look for updated compatable drivers,or once pc has started go to control panel select administrative tools , services , and scroll down to wzc(windows zero config)
select it and start it.close all box's and now you can use wifi using window based drivers(cos its the devices program(manager)that is incompatable not the actual device and the device is installed but its program disabled.
Dec 26, 2008 | HP Pavilion dv1000 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
354 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
