Question about LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
Cd rom will not run
Will not open cd program 98% of time
  • bryan Dec 02, 2008
    My cdrom tries to start,sort of vibrates then quits.Problem seems to have started when I wanted to burn some cd,s
Ummm call the manufacturer
Posted on Oct 08, 2008
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
Have a Dell 667Mhz 64mbit ram pc w/windows 98 on
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Mar 29, 2009 | Samsung SC-148 CD-ROM Drive
DLL PROBLEM
try right clicking on the program on your desktop and then click on properties after that click on compatibilty, next click the box next to run this program in compatibility mode, then click the box below that and select windows 95 or windows 98 / windows me. that should fix the problem. if not then you will have to uninstall and reinstall the game.
Mar 01, 2009 | Microsoft Windows Vista Ultimate Edition
CD drive door won't open.
there is a very small hole near the push button of your drive, put a pin into it and press it along with the push button
Nov 08, 2008 | HP Pavilion Slimline S3123W Desktop PC -...
Programme does'nt open
here is the solution for your problem :
A problem has been identified when installing early pressings of the CD-ROM on machines running Windows 98 or Windows ME in conjunction with certain antivirus software and firewalls. The installation appears to be successful but the OALD 7 Compass program fails to launch with no error message given, or with a message "License data invalid".
Should you encounter this problem:
  1. Download oald7.zip (4.5 megabytes)
  2. Unzip oald7.zip to extract the oald7.exe program
  3. Ensure your OALD 7 Compass CD-ROM is in your CD-ROM drive
  4. Replace the old oald7.exe file on your computer (this is usually found in c:\Program Files\Oxford\OALD7) with the new oald7.exe file you have downloaded
  5. You should now be able to run the OALD 7 Compass software
If the download doesn't work, we can send you this file on a CD-ROM - please email us , and tell us your full postal address. You will need to copy the update file to your hard drive to install it, as you will need your OALD 7 Compass CD-ROM in your CD-ROM, as above.
Please email eltdict.help@oup.com if you require further help.
See also: more information about the OALD 7 Compass CD-ROM
For help with other Oxford ELT Dictionary CD-ROM products, see the Multimedia FAQ page.
Mar 30, 2008 | Microsoft Windows XP Professional With...
Mp3 cd-rom
if u have window XP check the compatibility program to run the application u can choose window 98
Dec 24, 2007 | Computers & Internet
CD rom
Some CD drives have proprietary drivers but since it worked to install windows, we have a good clue to work with. Check and see if under device manager the IDE channels are working, this means not marked with a yellow exclamation mark. If one or any are, the protected mode drivers are locked. Open regedit and go to this key. HKEY_LOCAL_MACHINE > SYSTEM > CURRENTCONTROLSET > SERVICES > VXD > IOS Click on the NOIDE entry on the right side of the regedit program and hit delete. Close regedit and reboot, this will reset the protected mode drivers. If this doesn't do it, try changing from DMA transfer protocol to P10. It is on the settings page of the CD rom once you get it into device manager. If it's still not working, you may have use DOS mode drivers and that's to complicated to describe here.
Jul 30, 2007 | LG CRD 8481B (CRD-8481B) Internal 48x...
LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
137 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
