Question about Hampton Bay 24002 Ceiling Fan
Where can i get parts for my lighting kit? floresant light good , but light will not come on.
    Master:
  • 502 Answers
Is there power to the contacts?fuse?
Posted on Jul 04, 2010
Have a Hunter model 28675 ceiling fan with two light fixture. Turned lights on, heard a pop. One of the bulbs blew, turned black. Now the lights will not work with new bulbs.
Is the fan and light kit equipped with a wireless remote control? If so a short in the light fixture sockets will cause a backfeed into the electronic circuit boards of the remote controls receiver and burn it out. If you have a voltage tester or pigtail with a light bulb remove the screws for the light kit and disconnect the two wires from it. Connect your voltmeter or pigtail to the two wires that were connected to the light kit. Have someone turn on switch for light or push light button on remote and see if you are getting power, If you are then problem is in light kit. If no power is present then receiver for remote is burnt out. Depending on the fan receiver can be built into the fan or located inside the top canopy and can be easily replaced. As per the light kit having a watt regulator it is possible that was installed to prevent overheating of the sockets by the manufacturer. That can also have blown out causing no power to get to the bulbs. If you have power at the wires that connect to the light kit then the watt regulator is defective. You can bypass the part but you must insure that you do not install bulbs that are of a higher wattage then what the fixture is rated for. Or you can order a replacement from Hunter. Good luck.
Jan 27, 2018 | Electrical Supplies
Need help finding replacement light globes for ceiling fan light kit
That,s a low-end store brand fan for Home Depot. Good luck!
Nov 02, 2015 | Hampton Bay Dryers
Vizio lcd 42 turns on then backlight turns off
replace the inverter: it works like a floresent lamp ballast to light up your tv
Feb 18, 2013 | Vizio M420sr 42-inch 1080p 120hz Led-lcd...
Do you have to have two fluorescent bulbs working in a circuit for them to light up?
if you are talking about a 2 bulb floresent fixture, then yes, both bulbs have to be in and good for the light to work.
Oct 03, 2010 | Garden
I have a '95 Oldsmoblie Achieva, (2.3L 4 cyl.) that is leaking oil. I can't determine where it's coming from since there is oil covering the entire bottom of the engine. I doesn't seem to be coming from...
About the only way to determine where the leak is coming from is to clean the under carriage and drive it for a few days. A small leak can make a big mess and going down the road will cause the oil to spread everywhere making it impossible for the origins to be found.
Aug 14, 2010 | 1995 Oldsmobile Achieva
Can you replace light kit on Hampton Bay ceiling fan, Model-Cessna
Yes..
There are a bout three screws that hold the light part to the fan.
Make note of the wiring before you disconnect it also.
Remove the screws and the wiring will be exposed as the light part drops down...
Check the diameter of the light parts and find a new light kit that will fit it...
The Hampton Bay fans are exclusive to Home Depot, so most any of their light kits will fit, but any kit the right diameter will work..
Heatman101
Mar 05, 2010 | Hampton Bay Cessna 04313 Ceiling Fan
Fickers like a strobe light
you either have a bad inverter board or bad floresant tube in the lcd panel Tops Electronis in Haverhil mass can fix you right up
Nov 18, 2009 | Vizio GV42L 42 in. LCD Television
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
No Image on Monitor Westinghouse L2046NV
well i just had this problem this morning i woke up turned on the monitor and it came on but went out. but i soon found out it was not the display that is not coming on its the black light. if you look closely you can see the display but there is no light to light it up so you can see. it doesent seem to be anything wrong with the circuit board just the black light i am going to be taking the monitor apart to see if there is anything me or any of you can do for the monitor to fix it.
Jul 26, 2008 | Westinghouse L2046NV Monitor
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Hampton Bay 24002 Ceiling Fan Logo
73 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
