Question about Sony VRDMC10 DVD Recorder
Want to burn video non Blue-Ray DVD using AVCHD video as source. Can this be done on Sony VRD-MC10?
  • Sony Master
  • 6,993 Answers
yes, it is very possible to carry out the action with Sony VRD-MC10.
Connect a DVD player to the "IN-PUT" of the Sony VRD-MC10. I believe you should know how to do the connection between the Sony VRD-MC10 and any external player.
But if you have any problem with the connections, please let me know.
Good luck.
Posted on Jul 04, 2010
  • kelsey971 Jul 05, 2010
    Thank you for your suggestion.
    We have already burned may DVD's and find the VRD-MC10 quite friendly. The problem we are having is that the DVD's will not play on a standard (non Blu Ray) DVD player if we have started with a Sony camera using video format AVCHD.
I am trying to make a dvd from a HDD video cam to a sony DVDirect recorder VRD-MC3 and a message saying non supported USB devbice keeps comiong up. Can you hellp?
The manual of the DVD doesn't say much for models, say's sony HDD, sony DVD, so maybe it's not compatible. Do you have a memory stick for the handycam ? If you stored the video on the internal storage, check the manual to see if you can move it to the memory stick, then put the stick into the DVD player. Or you will need a PC to transfer it with USB, then get a memory stick and put all the video on in and not internal storage, if the DVD is not compatible with the handycam.
Mar 30, 2013 | Sony DVDirect VRD-MC3 DVD Recorder
Tip
How to burn AVCHD Lite to DVD on Mac OS X?
AVCHD-Lite, which is a subset of the AVCHD format popularized by hard disk camcorders from Sony, Panasonic, and Canon, uses h.264 video coupled with AAC audio for recording movies. AVCHD Lite video is currently used by Panasonic DMC-ZS3, Panasonic DMC-FZ3, Sony, Cannon AVCHD Lite Camcorder, etc.
26b78f7afa860b1f_2_197_.jpg The main differences between AVCHD Lite and the regular AVCHD: a maximum resolution of 1280 x 720p in AVCHD Lite compared to 1920 x 1080p in regular AVCHD and a less-intensive compression method - both of which make the format more suitable for less powerful camera hardware.
What you need to burn AVCHD Lite to DVD on Mac OS X?
Neither of AVCHD and AVCHD Lite video is directly supported by iMovie or iDVD on Mac OS(10.6.3 Snow Leopard included) if you want to burn AVCHD Lite to DVD. There are 3rd-party solutions that work with varying degrees of success in allowing you to work with AVCHD Lite video on Mac, like Daniusoft DVD Creator for Mac . It is DVD Burner that can convert AVCHD Lite video to DVD. With it, you can add DVD menu, edit videos and pictures, add transitions and effect, etc.
Below is the step by step guide on how to burn AVCHD to DVD on Mac OS X
Step 1. Load files Just click “+” button to import AVCHD Lite files to this program or simply drag and drop them to it. And rearrange the file list by using the up-down arrows.
Tips: You can freely drag and drop the thumbnail to merge or split the video files.
Step 2. Edit files (Optional) To personalize your DVD files, you can edit the video files by clicking “Edit” button. For video files, you can crop the frame size, trim into several clips, append effects, add picture/text watermark and rotate.
Step 3. Create DVD Menu (Optional) This Mac DVD Creator also allows you to create your own DVD menu with rich selections of DVD menu template. Simply click “Menu” button to select one and set the “Frame”, “Button” and “Text” to customize your DVD menu.
Step 4. Start to burn After all necessary settings, you need to insert a blank or rewritable disc to your Mac if you want to burn video files on DVD disc. Or you can simply convert the videos to DVD folder, .dvdmedia or ISO file on your Mac for later burning.
That is it! Within several clicks, you can burn AVCHD lite to DVD easily. So, why not download Daniusoft DVD Creator for Mac for a try?
on May 21, 2010 | Computers & Internet
Tip
How to burn MTS, M2TS Videos to DVD on Windows 7?
You have .mts/m2ts videos on your HD camcorder and want to burn it to the DVD disk? This tutorial will show you how to burn MTS/M2TS Videos to DVD on Windows 7.
Before we go to step-by-step guide, we need to understand a bit of background knowledge about MTS/M2TS. According to Wikipedia, both MTS and M2TS are Sony high definition video file types, which are raw AVCHD videos recorded by AVCHD camcorders such as Sony HDR-SR1 camcorders. And m2ts files usually record onto 8cm mini DVDS or blue-ray DVDS, SD memory cards and Memory Stick, or record onto hard drive camcorder
So, We have to convert MTS/M2TS videos to DVD video formats (MPEG-2)before we burn it to DVD disk. Fortunately, there is Wondershare DVD Converter Ultimate can burn mts/m2ts video to DVD directly. Importing your MTS/M2TS videos into it and insert a blank DVD disk to DVD Rom, with 1 click, it will bring you a DVD that is playable on your home DVD player. Sounds great? Let's go to the step-by-step guide:
How to burn MTS/M2TS videos to DVD
Step1 Download Wondershare DVD Converter Ultimate, install it and running
Step2 loading videos
Load video files that you want to burn into DVD disk.
Step3 Making a DVD menu
You can select DVD menu template on the left bar. Set background image and music from you local hard disk. Then, click "Next" button
Name DVD label and set video quality and DVD disk type. Click "Start" button. Then, you can take cup of coffee and waiting until it done.
Step4 Burn DVD
That is it, 4 steps to burn videos to DVD and enjoy it on your home DVD player.
on Dec 29, 2009 | Cameras
Dmp-bd87p-k won't play avchd videos
Through simple steps, this professional AVCHD to DVD Converter gives you an easy way to convert AVCHD to DVD without video quality loss so as to burn AVCHD to DVD to play AVCHD on DVD Player.You find it at
http://www.avdshare.com/play-avchd-on-dvd-player
Aug 19, 2012 | Panasonic Televison & Video
I want to buy a sony dvdirect mc10 does this machine have pal system. I live in UK.
MC10 is still only available for NTSC (US & Jpan), not PAL-format (the rest of the world).So dont buy it
Feb 21, 2010 | Sony VRDMC10 DVD Recorder
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
Canon DW-100
Thanks, I think it works that way. gl
Dec 08, 2008 | Canon DW 100 DVD-RW Burner
Both pics and movie to one disk
first, import your camera photos and video to computer
second, use a dvd slideshow software to combine videos and photos to slideshow and burn to dvd
finally play your camera photos and video on TV. You will experience more with good DVD authoring software.
More detailed info here: Create Camera DVD
Nov 29, 2008 | Sony VRD-MC5 DVD Recorder
Chapters & DVD menu
This is not a solution to your problem; but i can assure you that chapters do burn on my Sony Multi-Function DVD Recorder VRD-MC5. And, on viewing via a DVD player, work well.
wiljoycem@yahoo.com
Jul 04, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
No sound records on dvd
http://sony.storagesupport.com/dvdrw/vrdmc5dwn.htm
System Software Upgrade
Version: 30R2
Release Date: 01/06/08
New Features:
  • Allows VRD-MC5 to support Sony's 1920 x 1080 AVCHD Handycam.
  • Allows VRD-MC5 to record video directly from a MemoryStick memory card recorded using a Sony's MemoryStick Handycam camcorder.
Improvements:
  • Fixes problems with no audio during playback on certain camcorders recorded through 1394 or i-link connection.
  • Corrects signal detections with some camcorders as copy-protected.
Instructions | Download Updater (4 MB)
Dec 30, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Sony VRDMC10 DVD Recorder Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
