Question about Belkin (F5D7231-4) Wireless Router
I have forgotten my wireless net work password and need to add an iPhone to it. Can you help?
  • 2,263 Answers
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on Jul 03, 2010
Retrieve password
Login to the router, and set a new password.
Feb 03, 2014 | Western Digital WD My Net N600 - wireless...
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
Sep 10, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Can't find my wep key or admin password
If you have forgotten both you will need to restore your router to factory settings and re-add your internet details ***NOTE*** you will most likely have to contact your ISP for your account details so you can add your net details.
To restore there is a small pin hole on the back of the router with reset below it push and hold for 30secs this will revert your router back to original settings and change your login details to username: admin & password: admin. You will now need to run the setup wizard to setup your router and internet details which will allow you to input a new wep key.
Once done you will need to re-connect each device on your network with new details.
Hope it helps.
Thanks.
Nov 27, 2010 | SMC Barricade g SMC2804WBR Wireless Router
My iPhone does not connect to the Zoom X6 DSL modem. I can connect my laptop and a couple other wireless devices but not my iPhone. Is there a setting I should change either on the router or on my iPhone?...
there is 2 possibility 2 change in router first WEP or wpa security code if in your router need password for connect it then you need to find that key code to enter in iPhone.
Second if in router MAC filter is enable then you need to add your iPhone MAC address in allow list of router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
First find the mac address of your iPhone in network setup menu then add that mac id in mac filter of router configuration menu.Then save settings and check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 05, 2010 | Zoom X6 (5590) DSL Modem (55900003)
I need help setting up my email on my iphone
1) If this is the first email account you're setting up on your iPhone, tap Mail. Otherwise, from the Home screen, tap Settings.
2) On the Settings screen, tap Mail.
3) On the Mail screen, under Accounts, tap Add Account.
4) On the Add Account screen, tap Other.
5) Select POP and then enter your account information using your keypad. Name Enter your name. Address Enter your email address. Description Enter a description of this email address. The description displays in your email account list on your iPhone. 6) Enter your Incoming Mail Server information.
Host Name Enter pop.secureserver.net. User Name Enter your full email address as your user name. Password Enter your password for your email account. 7) Enter your Outgoing Mail Server (SMTP) information.
Host Name Enter smtpout.secureserver.net. If you need to change your port, use one of the following for your outgoing mail server, depending on the port you want to use:
smtpout.secureserver.net:25
smtpout.secureserver.net:80
smtpout.secureserver.net:3535
User Name Enter your full email address as your user name. Password Enter your password for your email account. Note: The user name and password for your outgoing server is the same as the user name and password your entered for the incoming server.
8) If SSL mode is enabled, under Outgoing Mail Server (SMTP), tap Advanced.
9) Set Incoming Uses SSL and Outgoing Uses SSL to OFF.
Jul 16, 2009 | Apple iPhone Smartphone
Have forgotten NetKey password to add laptop to wireless network
Just reset the router and you can configure it again like before.
Jul 01, 2009 | Linksys Wireless-G WRT54G Router
Set up email using Comscast.net on my iphone
Settings icon on the Home screen, select Mail, Contacts, Calendars and select Add Account. Select Add Acount. Select Other.
Put in your name, email address and password. It should be able to look up the pop and smtp info; however, if it doesn't:
Comcast incoming mail server: mail.comcast.net
Comcast outgoing mail server: smtp.comcast.net
Hope this helps,
BReady
Jul 01, 2009 | Apple iPhone Smartphone
Need to add another laptop computer to my wireless router at home
Try (admin) for your password and see if that works for you. Good luck.
Feb 18, 2009 | Linksys Wireless-G WRT54G Router
Forgot my password
please follow the following steps:
1) Click Start > run > cmd > ipconfig (enter) and note down the Deafult gateway should be some numbers like 192.168.1.1 etc 2) Open internet explorer and type those numbers in the address bar and press enter 3) now you will get the router page, login with following details username: admin password: admin or password 4) and in wireless settings you can find the password (WEP) to connect the IPhone
Jan 27, 2009 | Linksys Wireless-G Broadband Router
Belkin (F5D7231-4) Wireless Router Logo
196 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
