Question about Sony VAIO VGN-NS160D/W Notebook
What is the maximum amount of ram that it can the memory be upgraded to?
    Brigadier General:
  • 10,406 Answers
The manufacturer's web-site:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=VGNNS160DW
is totally non-helpful.
If you have the 32-bit version of Windows Vista, then the maximum supported by Vista is 3GB.
If you have the 64-bit version of Windows Vista, then the maximum supported could possibly be larger.
But, of course, the motherboard would have to support more than 2GB.
Best advice: take the computer to a computer-store, get them to install more DDR2 RAM, and see if the computer will recognize all of the RAM.
Posted on Jul 04, 2010
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
Can I upgrade the ram on the acer aspire 5630 notebook?
Yes, you can.
You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Nov 25, 2010 | Acer Aspire 5630 Notebook
Is there anything you need to do before or after upgrading your memory card in an hp laptop
If this in reference to the Ram Memory module/s, the answer is No.
Things to know about upgrading Ram Memory in a computer.
A) What is the Maximum TOTAL Amount for the computer. (Motherboard)
B) What is the Maximum Amount for EACH ram slot.
C) What Type of Ram Memory does the computer support. (Motherboard)
D) What frequency rate of Ram Memory does the computer support. (Slang for Frequency Rate is 'Speed')
If you have the correct Ram Memory, and are only installing 1 Ram Memory module, be sure to install it in Slot 1. (Also referred to as DIMM 1)
This is the Ram Memory slot the Processor reads first.
If I knew what HP laptop computer this was, such as the Product Number, and I knew what Ram Memory you are installing, I could help you further.
On the bottom of the laptop is a white Service Tag.
P/N = Product Number
(S/N = Serial Number. Do Not give this out online, except to HP Support)
If your problem does not regard Ram Memory, please disregard this solution.
Oct 06, 2010 | Computers & Internet
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
I want to upgrade my memory on my Pavilion 513n,
FixYa is a product support website, and as such we do not delve into manufacturing. No we cannot supply ram memory.
I can supply you with the solution to your questions, however.
This is HP Support, and the main page for the Pavilion 513n Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/product?product=90384&lc=en&cc=us&dlc=en&submit.y=5&submit.x=6&lang=en&cc=us
If you click on > Product information > Product specifications > HP Pavilion 513n Desktop PC Product Specifications,
you can view,
A) What type of ram memory the computer uses,
B) How much is the Maximum Total Amount for the computer,
C) How much is the Maximum Amount for EACH ram slot,
D) How many ram slots
Look under the Memory heading.
Type - DDR
It's DDR Sdram
Speed - PC1600/PC2100
Tells you either PC1600 can be used, or PC2100.
PC1600 is DDR Sdram that operates at 200MHz.
PC2100 is DDR Sdram that operates at 266MHz.
{To expound:
Ram memory operates at a Frequency Rate. Slang for frequency rate is 'Speed'.
Mega = approximately 1 Million
Hertz stands for Cycles per Second
Example: PC2100 is DDR Sdram that operates at 266 Million Cycles per Second }
B) What is the Maximum Total Amount for the computer. (Motherboard)
According to HP it is 1GB.
{Maximum - 1GB (2 X 512) HP recommended maximum}
I believe this to be wrong. The Total Maximum Amount is 2GB.
1GB per ram slot.
I base this upon using the memory configurator's of several websites, that sell ram memory for the Pavilion 513n desktop computer, and looking at what the motherboard chipset for the Pavilion 513n will support.
The motherboard chipset is the Intel 845GL.
This chart found on Wikipedia, states what the Intel 845GL chipset will support,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
As you can see reading across from the 845GL subheading, and looking under > Max.memory, 2GB is listed.
Sources for online memory configurators,
1) Crucial.com
2) Tigerdirect.com
3) Newegg.com
4) Memory4less.net
In this case,
C) Maximum Amount for EACH ram slot is 1GB.
D) There are Two ram slots. {Proper speak for ram Slot is ram Bank}
Kingston is a good brand for economical ram memory.
So is Ultra.
An easy way to find out what type of ram memory you need, and how much is the Maximum Total Amount, as well as the Maximum Amount for Each ram slot, is to use an automatic scanner from a website that sells ram memory.
The above four websites listed, are but a small handful of the total websites online that offer an automatic scan.
Let's use Crucial.com for an example.
On the main page,
http://www.crucial.com/
,you will see - Scan My System, in blue.
Simply click on it to run an automatic scan of your computers hardware.
Doesn't look at your personal effects, just the hardware of your computer.
After the scan is done, you will be presented with the ram memory info you need.
Several options of ram memory are presented for you to choose from.
Apr 26, 2010 | HP Pavilion 513n (P9850A#ABA) PC Desktop
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
Upgrades and advice!!!!!
2GB is the maximum amount of ram you can install in your Dimension 2400. Depending on how much ram you have in it now,.. you could get a substantial speed difference by upgrading. You can upgrade the video card if you want. If you want to upgrade to 2 GB and upgrade to a decent vid card,.. you are looking at about $180 for parts. you will need to determine if that is something you want to put into the 2400 or buy a new computer with substantial speed and performance difference for about $500 from Dell. If you have any further questions, please post a comment here and I will answer them for you.
Feb 08, 2010 | Dell Dimension 2400 PC Desktop
After I upgraded RAM from 512 MB to 2 G, my computer can not resume from stand by mode.
1.Do you know what the Maximum TOTAL Amount is for your ram?
2.Do you know what the Maximum Amount is for EACH ram slot?
3.What is the computer manufacturers name, model name, and model number?
(Example: Compaq Presario SR1110NX.
Compaq: Computer manufacturers name
Presario: Model Name
SR1110NX: Model Number
(Not trying to insult your intelligence with Number 3 above)
Reason for asking Number 3?
Let's take an example. Let's say your computer has a Maximum Total Amount for ram memory, that is 2GB.
EACH ram slot's Maximum Amount is 1GB, and you have two ram slots.
If you install a single stick of 2GB ram in Slot 1, chances are it isn't going to work.
If I know what computer you're referring to here, then I can give more of an exacting solution.
Sep 25, 2009 | Epson Stylus CX4800 All-In-One InkJet...
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Sony VAIO VGN-NS160D/W Notebook Logo
98 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
