Question about Karcher 2500 PSI Pressure Washer
I have a gc160 honda pressure washer. when trying to crank the washer with the pull cord it acts like it wants to crank but never does.i have changed the sparkplug took the carb. off and cleaned it throughout and also had the fuelpump checked to see if it was weak. it has blowby comeing out of the breather so i know its getting fire to the plug. please help me with this problem. thanks, Gary
  • clark2473 Jul 05, 2010
    There is no water pressure on the gun since the hose is not hooked up. The engine shouldn't have worn rings,it is not that old nor has it been used that much.
    Master:
  • 501 Answers
Release the water pressure on the pressure gun.that helps.shouldnt have blowby coming out the breather.that indicates worn rings.do a compression check.should be at least 90-130 PSI
Posted on Jul 03, 2010
  • Ian Summerfield
    Ian Summerfield Jul 05, 2010
    you shouldnt start the motor without water in the pump,youll damage it.connect the hose!..you still should not have blowby,do a compression check,the oil level sender unit[if its got one]will kill the engine if low level.Hondas wont start unless choke fully on.N11Y champion spark plug.drain carbie bowl,to see what comes out,and if fuel comes out,check the flow.sometimes,Hondas have been known to snap a valve rocker pedestal .
Starting a small engine.
place it back up the right way
remove the spark plug
fill the sump to the correct level
pull the cord a few times to expel any excess oil out of the cylinder
remove air cleaner to remove any excess oil from the filter
clean the plug by washing in solvent to remove oil
install plug, prime or choke and it should go
will smoke for a while until the oil in the muffler burns out
Jun 24, 2016 | Honda GC160-QHA 3/4" Shaft Recoil Start 5...
Keep getting gas into crank case on honda gc160
Check crankcase hose to air cleaner.
Mar 20, 2016 | Honda Garden
Broke the plastic gear inside
You did not say engine make or modell number (i.e. Honda GC160). A great place for parts is Presure Washer Store and Small Engone repa
Oct 23, 2012 | Garden
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
My pull cord broke on my honda p.w. and replace and had bad pump
Before you trash the pump, try this. Get a very good flush through the entire system from faucet to trigger. Let it run for say, 5 minutes. Make sure that there are no high spots in the hose supply line where air can be trapped. Once done, start the engine, but this time with the trigger depressed on the spray nozzle. This acts like an unloader, and makes it much easier to start, as there is no back pressure. I had a P/W that I had to crank that way. It worked for me. I have a new one now, and I still crank it the very same way. One last tip: If you need to shut down the machine, say, for a pit stop or lunch, leave the trigger depressed with the engine off. It allows the pump to cool, and makes re-starting much easier.
Best regards, and please rate this solution. Thanx, --W/D--
Jul 23, 2009 | Honda Pressure Washer PSI 3000
Washer want stay running. I can pull choke and it
mr fixit, I have pressure but it just want stay running
Jul 11, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
381 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
