Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
What is the output amps on robo kleen transformer
What is the amps on robo kleen transformer
  • 640 Answers
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
Posted on Oct 12, 2010
What do your do to help kids
Yout question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner is "What do your do to help kids"
Really, I have no idea what do you want to ask
Reformulate your questoin.
May 04, 2015 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen is moving but wont suck up the leaves and dirt
Possible blockage in the base where the leaves enter into the bag.
Jul 20, 2014 | Smartpool Robo Kleen
My robo kleen is oily
that is pool water mixing with some kind of lube
take off the metal plate and drain plug
let water drain out
Sep 05, 2013 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
Robo comes on but wheels dont turn and robo just sits there.....I cna see no physical problems as all else appears to be working fine. Thanks for any assistance you can provide. Robo Kleen in new as...
Make sure that your impeller is not clogged. Occasionally hair or linen may get caught in the impeller. Take the top grill off by removing the 2 screws from the top, with the transformer unplugged. Remove the debris and replace the grill. You will also want to check for obstructions in the axle of the drive shaft. Sometimes even small debris can cause the wheels not to turn. You might also want to remove the limit screw for greater wheel movement. These are all pretty common problems with these pool cleaners. Unfortunately, it could also be a problem with the gear box. If this is the case, you will need to have it services professionally.
Jun 11, 2011 | Smartpool Dolphin Robo - Kleen Above...
I have a smart pool dolphin robo-kleen pool cleaner. It keeps blowing fuses. Can you help?
If it is blowing fuses, it sounds like it is going to be your connection to the transformer and not the pool cleaner itself. Unfortunately, if you are not a trained electrician, you should not attempt to fix your transformer. It is very dangerous to try to adjust electrical settings without training, and I can't recommend that you do that.
Apr 12, 2011 | Smartpool Dolphin Robo - Kleen Above...
Robo-kleen only moves back every 2 feet.
You need to check your impeller and your axle bearings. To check the pool cleaners impeller, make sure that the transformer is unplugged to prevent electrical shock. Take the top grill off by removing the 2 screws from the top. Remove any debris that you find and replace the grill. Secondly, check all of the axles and the wheels for debris, hair, or lint that would restrict movement. Make sure that you do not force the wheels. If you aren't able to fix it with these solutions, it could be your gear box or another electronic section of the cleaner. You will need to have it services professionally.
Aug 30, 2010 | Smartpool Dolphin Robo - Kleen Above...
Same thing brand new
I'm not sure what your exact question is, but below is a copy of the users manual for these pool cleaners. It should help you trouble shoot whatever problem you are having.
http://www.backyardcitypools.com/images/smartpool/robo-kleen%20-Manual.pdf
Aug 21, 2009 | Smartpool Dolphin Robo - Kleen Above...
Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Aug 16, 2009 | Smartpool Pool Hog Ig Robotic Automatic In...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
288 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
