Question about Nikon Speedlight SB-800 TTL Flash
Replaced flash circuits
I've just had both SB 800's die, uncannily, within the space of a week of each other, sent them to Nikon and now unfortunately its going to cost £160 each to replace the flash circuits on them both. Considering I can buy new SB800's for £204 w/warranty, is it worth repairing them (they're both under 2 yrs old and now out of warranty) ? Is this likely to happen again in the future? They've been worked hard, but that's what they're designed for surely!
    Genius:
  • 1,646 Answers
There can be two schools of thought for this.
When replacing the circuit board in a flash, this means that the lamp, photocell, LCD display, and the switch pads are the old ones. I would guess the main power inverter board is being changed.
What usualy fails on this board is the main electrolytic capacitor. Not always, but other parts can fail. If it is only the main capacitor, this can be bought at most any major electronics parts distributor. You only have to specify its value in MicroFarids, the mechanical size so it will fit, the lead configuration, and the Voltage rating.
As long as the voltage rating for the new one is the same or greater, and the size configuration is close, the new cap would most likely work. This type of cap is not very expensive compared to the cost of a complete board.
If other parts are also defective on the board, it may be impossible to service unless the part is a generic type. If the part is an SMD surface mount type, depending on the configuration, someone who has SMD soldering tools can replace the part.
I have repaired about 80% of the problems in photo flashes. I only send them out if the fault requires a complete board change or factory calibration. With a new board, calibration will probably be necessary.
Bottom line for me: I would buy new flashes if I had to pay out more than 60% of the cost of a new replacement. But, that is my personal view.
Jerry G.
Posted on Apr 19, 2008
Are the sb-900 and the sb-800 heads the same? I have a sb-800 and I want to buy teh coco ring flash with the sb-900 adapter, are both the same, will it fit the sb-800?
No it is not the same. the SB 900 is 25% bigger.
I just got a Coco ring for my SB 800 (I bougth the one for the SB 900) and it is big. But I just filled the empty space with hard foam and works wonders. I can post a photo if you want.
By the way I have a D 700. It migth fit different in other cameras.
Jan 13, 2011 | Nikon Coco Ring Flash Adapter(49368824316)...
Why is my sb-800 melting my batteries?
Thre is a non-repairable short in the capacitor charge circuit that puts a big amp load on the batteries.
May be repaired by Nikon service... but the electronics contain high voltage. Do not attempt to repair yourself and I wouldn't trust it even if Nikon repairs it. Why risk burning your camera and equipment!?!
--sorry--
Sep 12, 2009 | Nikon Speedlight SB-800 TTL Flash
SB-800 -3EV message after about 50 shots or so
IN THE INSTRUCTION MANUAL USING THE FLASH IN SHOOTING FAST CAUSES IT TO HEAT UP .
TRY USING THE FLASH IN MANUAL AND CUT THE RATIO POWER AND USE AS A FILL AND NOT A MAIN .
YOU COULD ALSO USE TWO NIKON SB800 FLASHES IN ITTL AND WITH TWO THE FLASH IS USING HAVE THE OUTPUT AND RECYCLE TIME IS INCREASED .
DAVE BLACK A WELL KNOWN PHOTOGRAPHER DOES THIS IN HIS SHOOTING .
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
Nov 13, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb-800 sync
Make sure the slave is not set to rear curtain or slow flash. Otherwise Send that back to Nikon for service. http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Aug 02, 2008 | Nikon Speedlight SB-800 TTL Flash
SB 800
Contact Nikon Product Repair1-800-645-6678
Telephone Support is Available 8am EST to 2am EST 7 days a week.
Jul 19, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon sb800 speedlight
The trigger circuit and flash tube needs to be replaced . If you want me to repair this contact .
Berrie Smith Camera Repair
bbmw@bellsouth.net
770-312-0719
Mar 27, 2008 | Nikon Speedlight SB-800 TTL Flash
New SB-800 died
CHECK THE BATTERY CONTACTS AND MAKE SURE THEY ARE TOUCHING. iF THIS IS NOT THE PROBLEM THEN
YOU HAVE TO SNED IT BACK TO THE FACTORY WITH RECIEPT FOR WARRANTY REPAIR .
'THE MAIN BOARD IS DEFECTIVE
Mar 29, 2007 | Nikon Speedlight SB-800 TTL Flash
The battery damages my SB 800 Mainboard
IF YOU HAVE THE BATTERIES , YOU CAN SEND THE UNIT TO THE BATTERY MANUFACTURE FOR REPAIR .
BE SURE TO GET THE ADDRESS OFF THE WEB SITE AND ALSO ENCLOSE THE BATTERIES WITHTHE UNIT TO SHOW THEIR BATTERIES DID THE DAMAGE .
A new main circuit will have to be re programed and you have to sent it to NIKON
bbmw@bellsouth.net
Jan 02, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
137 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
