My matshita uj-860s disc drive has stopped working
  • 2 more comments
  • Anonymous Aug 27, 2008
    My Matshita uj-860s DVD Drive also stopped working. Can not find a driver anywhere!
    Any solutions?
  • Anonymous Nov 29, 2008
    mine too
  • Anonymous Dec 20, 2008
    my optical drive is a uj-860s as well. I have sporadic problems with both vista and xp not finding the device, as well as it not reading DVDs or CDs. I think its mechanical but the lack of both firmware and or drivers or even panasonic acknowledging the exsistance of this ODD is very annoying.
  • Anonymous Jan 11, 2009
    Same problem
In my case, MATSHITA DVD-RAM UJ-860S did not want to write CD-R,-RW Verbatim using software NERO 8, but is easy to write their own software windows XP.
in the Log file was as follows:
Could not perform start of Disc-at-once
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Power calibration error
whether
Invalid field in parameter
E: MATSHITA DVD-RAM UJ-860S
ACTION! :)
Change in method of recording NERO 8 Burning mode: DAO (Disc-at-once) at Burning mode: TAO (Track-At-Once) all have established!
Simply drive MATSHITA was UNSUPPORTED software producers to write disks.
Updating the software to burn CDs, as is windows XP supports the recording and includes drivers for the drive! :)
Posted on Feb 23, 2009
  • werland622 Jan 24, 2011
    the good question here is why is this dvd drive model not in any matshita/panasonic database. it is like this drive did not exist on them. no firmware update also. this is strange.
3 Suggested Answers
SOURCE: matshita uj-860s disc drive has
Windows XP?
Use regedit:
Delete parametrs "Upperfilters" and "LowFilters" in reeestr
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Reboot computer
/ Leshiko /
Posted on Mar 30, 2009
  • 479 Answers
SOURCE: my matshita uj-860s disc drive
Please try the following
1.START>RUN>REGEDIT press enter and the registry editor will be opened and then the values could be opened by double clicking on each as follows
H_KEY_LOCAL MACHINE>SYSTEM>CURRENT CONTROL SET>CONTROL>CLASS>single click on first entry starting with 4D(it will be 4DE3695 like) and check for any lower or upper filter on the rigt hand side pane and if there please delete them)
2.Go to the device manager and then right click on the exclamation mark entry and uninstall it.
3.Go downwards in the device manager and open the IDE ATA/ATAPI controller and uninstall the values either ATA channel 1 or secondory IDE channel.
4.Restart the system twice and if then also the issue is not resolved then u will have to reinstall the OS.
Posted on May 28, 2009
I have an Asus 3FS, and my Matshita dvd-ram UJ-860S ATA wont read certain dvd's. I've tried deleting lower and upperfilters and have used Microsofts troubleshooting - still wont read some dvd's and have...
Ok try resetting the BIOS to default value by restarting the computer and pressing F2 Key or Delete Key to Enter BIOS setup then select Load Default settings or any option which shows as default settings depending on the BIOS Manufacturer. Now check if it is working, if the issue persists try booting any Operating System Discs like Linux or WIndows to confirm if it is working properly.
Mar 02, 2011 | ASUS Computers & Internet
ASUS M51SN Matshita BD UJ-120 burner does not work - Windows 7
this will be an isue with the drivers for the drive you will have to get the windows 7 drivers
May 19, 2010 | ASUS M51Sn-C1 Notebook
Matshita UJ DVD-RAM 860s can't burn CDs or DVDs
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start
Start button, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
The system will automatically rebuild the registry records when you restart your computer. Hope this helps.
Mar 27, 2010 | Computers & Internet
My optical drive cannot write or burn cd/dvd
TRY PUTTING IT INSIDE THE HARD DRIVE AND THEN IT WILL SAY A BLANK CD HAS BEEN INPORTED
Nov 28, 2009 | ASUS F3SV-B2 Notebook
My matshita uj-860s disc drive has stopped working and for the dvd's? what i can do? asus f7kr
May 28, 2009 | ASUS Computers & Internet
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
Matshita uj-860s disc drive has stopped working
Windows XP?
Use regedit:
Reboot computer
/ Leshiko /
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
4,023 people viewed this question
David Payne
David Payne
