-   I thought by inserting a memory card into my blackjack I wouldn't have the same problem and now i have inserted a memory card into my blackjack but it says it cannot access the card... HELP! -   gkrates
Feb 12, 2009
-   whenever i have to take movies or anything on from bluetooth it shows memory full whereas i have 1gb extendable memory which is empty so plz tell me how to use that facility
-   hemant609
Jan 17, 2009
-   Same exact issue here. Cant find anything in the main memory that has it s full?-   Guest
Dec 30, 2008
-   memory critically low-   Guest
Dec 20, 2008
-   My Q9m also is now consistently showing critical low storage but I have looked through the file manager & cannot find any non critical files or programs to delete. Does anyone know how to find out what is taking up all the memory? The memory manager is useless. It gives you data about the memory but doesn't give you any options on how to change any of it.-   Guest
After deleting all temporary files in EXPLORER (under menu) you can do this. (this freed up at least half of my memory).
Start - Applications - File Explorer - (hit the up button) - Windows - (this takes a moment or two) Messaging. You will now see the attachments folder with one or more files under it. These files are where downloaded messages seem to be stored forever, even if you delete them from all folders in your email accounts. Delete all of these files and then check your memory.
hi, I had my N96 blocked as I thought I had lost it. I have now found it...can you please advise me...
(More)
hi, I had my N96 blocked as I thought I had lost it. I have now found it...can you please advise me on how I can unblock it. It will not turn on. Thank you
window can not recognize my compaq pocketpc 20002 premium w/outlook, ineed free software that enable...
(More)
window can not recognize my compaq pocketpc 20002 premium w/outlook, ineed free software that enable window synchronize device
Every time I start the MDA Pro up I get the message: "Storage memory is critically low. If you do not increase storage memory, you may not be able to start some programs. Use File Explorer to delete files you no longer need, or move some files to a storage card."
Needless to say, I've searched for large files but cannot see any that may be removed. I did see some strange files in the Windows directory with a dsm extension. Can they be deleted?
