Question about Hampton Bay Dryers
Fan no longer responding to remote control
UL model # 52-CS; UPC 082392460129
the batteries were changed in the remote control, but when I try to change the speed, the fan's speed does not change accordingly.
  • Ian Summerfield
    Ian Summerfield Jul 03, 2010
    have you put batteries in right way round?does the screen have clear figures[if it has a screen].try more batteries
  • 51 Answers
SOURCE: Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Posted on Jul 25, 2007
  • 323 Answers
SOURCE: Receiver won't fit Model 52-CS
Turn the breaker off first.
You'll have to take the fan down and of course disconnect the wires. I run into this a lot. What I do is take a razor knife and cut carefully into the ceiling on the side of the box, Then connect the wires from the box to the remote module with wire nuts. I always wrap them in a couple turns of eletricians tape.
Then connect the long wires to the other end of the module and push it up through the slot I cut out and lay it flat on the top side of the ceiling.
When you put it back together the part that goes against the ceiling will cover the hole in the sheet rock. Pain in the rear, huh?
Sirwriter
Posted on May 15, 2009
  • 19 Answers
SOURCE: Fan not responding to remote
Check to see if the remote switches of your hand held device match the switch setting in the fan assembly
Posted on Sep 15, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Posted on Jun 09, 2010
mcdevito75
  • 1970 Answers
SOURCE: hunter 52, fan works but light no longer works
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Posted on Jul 22, 2010
Remote control does not respond
If the case is not damaged, remove and re install the batteries. That generally fixes problems like this. If not you will have to replace it.
Dec 25, 2013 | Hampton Bay 52 In. White Redington...
Remote for Ceiling Fan (Model: AC 552 AL) no longer works. I changed out batteries and still does not work
Maybe it needs to be reprogrammed after new batteries. What is the model number on the remote, please?
Jul 12, 2010 | Hunter 52" Ceiling Fan With Light And...
Sep 15, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay Cessna Glass Globe Replacement
I don't think King of Fans manufactured your fan, BUT their FAQ says...
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
Mar 08, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay Fan 55295 remote control
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30-Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan you will be able to get to the needed additional information.
After downloading and reviewing my fan's Owner's Guide, and reviewing the online FAQs, I called 1-800-330-3267, concisely described the problem, and ordered the parts needed with only the fan name and SKU.
I and am about to order more parts after suffering a power surge (The needed info was in the FAQs). My experience is great customer service and speedy delivery of the needed parts.
One of their FAQ's answers the question:
Jan 25, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Dryers Logo
198 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
