Question about Tools & Hardware - Others
I have a agatec gat120 laser level it is supposed to self level but its stopped doing that, is there an easy solution?
2 Suggested Answers
  • 87 Answers
SOURCE: DEWALT LASER LEVEL SELF LEVELING THE LIGHT LASER
Laser diodes are no like light bulbs. When a light bulb burns out, it goes black. When a laser diode burns out, it goes to an extreme low power state. You can see red at the source, but there is no beam to speak of. If this is what you're seeing, then contact Dewalt. They are low quality instruments, but will try there best to get you a new one, at a reasonable price.
Posted on Sep 05, 2015
How to get it to do self clean and how long is it suppose to take
Electrolux Self-Cleaning Oven ' Electrolux Kitchen Range ...
? 0:47
https://www.youtube.com/watch?v=JNVPSVe_MV0
Mar 25, 2015 - Uploaded by Universal Appliance and Kitchen Center
Electrolux fresh clean feature is the perfect ingredient for cleaneroven, with 3 different levels of cleaning .
Manually Starting Self Clean cycle on Electrolux Washer
ths.gardenweb.com > Home Forums > Laundry Room
Feb 10, 2011 - So, I want to do a self clean cycle manually. ... wake up washer by pressing any button rotate cycle knob to handwash press start and then cancel. ... I am not sure my machine is operating on the clean cycle.
Nov 23, 2015 | Electrolux Vacuums
How do I check if my dewalt spinning laser is accurate?
Set it up and shoot 4 level points around the laser . Like at 12 -3-6and 9 o clock. Move the laser 15 or 20 ft from where it is now and re-shoot those 4 points again .if they don't read level then your laser needs calibrated
Jan 07, 2015 | Dewalt Self-Leveling Line Laser...
What is the slope buttons used for
If you have the standard RL-H3C then there are 3 buttons. Starting from the left there is the "height alert" then "manual" then "Power".
Height alert is a function that after the laser levels and spins monitors the position of the laser. If the laser moves more then a tiny amount then the height alert function is tripped, and the laser flashes it's lights and stops spinning (or spins slowly) to let you know the base line position of the laser has changed. Pressing the height alert button twice shuts this mode off.
Manual mode means after the laser is leveled, it completely ignores the level vials. You can turn the laser any way you want to and it will always spin and not cause any errors.
Power is self explanatory.
If it's a RL-H3CS then it has two arrow buttons, that when in manual mode, allot one axis of the laser to be manually adjusted up and down to do a manual slope.
Sep 22, 2014 | Topcon Rlh3c Rotating Laser Level W...
Lazermark won't self level
There are 2 leveling systems in the lasermark lasers. The original was belt driven. The belts are rubber O rings, and break down over time. take the bottom off the laser and you can replace broken belts. It's a simply yet elegant system.
The newer ones use leveling cams. A tear drop shaped wheel on a motor, that raises and lowers one end of an axis to tilt the laser. The problem is because they have a hook at one end, they put a magnet in the cam to tell the laser when to stop turning the cam. If however, it reaches the limit, and then gets bumped it'll get the leveling axis stuck in the hook of the cam, and because the magnet is there, it will never relevel. What you have to do is, disassemble the laser, unplug the leveling motors and pull the wires for the magnet sensor out of the stuck axis. then swap the sensor from the other sensor in (as it wont level without reading the sensor) and then turn the unit on. It should be able to level at that point. The put all the wires back where they go, and you're on your way.
Apr 20, 2014 | CST/Lasermark Self-Leveling Rotary Laser...
My laser level wont come on
clean or scratch the contacts if you maybe sometime have had leaking batteries in the compart and inside and clean the white connector plug inside the laser (4 little black torx screws) where the red/black batterypower wire goes to and it is connected downside on the upperprint , becarefull with remounting the cap back for that wire is fully free that little contact must be carefully cleaned with contactspray spray it on something and a little drop is enough.
Its generally an easy laser to do a repair in Europe there are different spare parts for to get. I dont know if there can become different spere parts for this model.
Mar 05, 2014 | Dewalt Self-Leveling Line Laser...
I can't get my david white matrix 54 to shoot a beam in any direction. The lights on top just flasah.
This sounds like it is out of level. Self leveling lasers are only self leveling to a point. If they go past that they can not compensate and generally flash to let you know.
Jun 14, 2011 | David White 48 MATRX54 Matrix54 Multi...
Dewalt laser dw087 is blinking and cannot self level anymore (I assume)
this unit does not have any replaceable parts, if the unis is covered by warranty, it would be exchange, if not then check with your local servicenter the max rate program to do so.
Aug 30, 2009 | Dewalt Self-Leveling Line Laser...
Tools & Hardware - Others Logo
134 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
