Question about GE APN10AA Portable Air Conditioner
Water full light keeps coming on and shutting unit down. There is absolutely no water in it.
  • 53 Answers
Take out drain pan, and make sure, you put it back in all the way.
Posted on Jul 03, 2010
  • GE Master
  • 8,220 Answers
Check your float switch. It might be stuck in the up position.
A portable manual
note: while this is a different brand ac it gives an idea how they work and what to check
Keeps shutting self down
See manufacturer!
Search Results
    temp light comes unit shuts down Specialty Kitchen ... - Fixya
    www.fixya.com > Forum > Tags > temp light comes unit shuts down
    Specialty Kitchen Appliances temp light comes unit shuts down questions and ...The water in the jug gets hot, but the unit keeps shutting itself off before all the ...
    Bowled over by estimates for our kitchen renovation - Houzz
    www.houzz.com > All Topics > Design Dilemma
    HouzzFeb 2, 2014 - It looks cosmetically nice, but our appliances are 17+ yrs. and dying, the..... If you want to have beautiful and keep the cost low, I love IKEA for .... The real money in kitchen cabinets is in the "box" itself and the labor ..... The cupboards were bought from a kitchen company that was closing down a showroom ...
Jan 21, 2016 | Kitchen Appliances - Others
My air-o-swiss 7142 humidifier keeps giving me the empty indicator light to signify no water in the unit even though the base and the tank are full. If I try to reset it comes on for seconds and then shuts...
The water sensor is a float in the mister area of the base. The float is off in one corner with a little plastic barrier around it and translucent cap over it. Make sure the float can more freely. If the float can move up and down but the light stays on, the reed switch (a switch controlled by a magnet built into the float) inside the unit might have been knocked loose, damaged or disconnected. The switch is actually inside the post that the float slides on, but it can only be accessed from the underside - inside the unit.
Sep 20, 2008 | Air-O-Swiss U7142 Humidifier
Air conditioner wont work
When the STOP indicator light turns on, the internal water tank has filled with condensed water and the air conditioner will turn off automatically. You can drain the internal water tank by removing the plug on the back of the unit, be ready for a lot of water to come out of the unit. The unit will shut down when the water pan is full. This condition may occur either when the unit is operated in high humidity conditions, or when the unit is being operated in HEATMODE, since the auto-evaporation function will not work in the heating mode. I hope this helps, have a great day, Andy K.
May 22, 2013 | Heating & Cooling
Fluidmaster model 200a, water keep on filling inside the tank even when it is full.
ok,, if you can lift the arm and it shuts off its just aligned wrong, shut off the water, reach down to the lower half of the fill tube,, you will see a little slide clamp, that slides off, and you can adjust the unit up or down to set the amount of water the tank allows to fill and turn off , also, if the over flow ( the small black tube) that goes down the tube that holds the flapper ball, is too far down inside of that tube, it will create a siphon so make sure thats attached to the metal clip that comes with the unit. If the water doesn't shut off when you lift the arm on the float bar,, you can turn the top of the unit 1/8 of a turn, and remove the top, check for any debris inside of that , you can invert a cup and hold it over the top long enough to shoot a short blast of water to clear the feed out. reassemble, and turn the water back on,, you may have to readjust the slide tube to the desired water height
Jul 08, 2011 | Plumbing
LX-140 SOLEUS A/C DUMPED WATER ALL OVER MY WOODEN FLOOR........THE TANK ALWAYS GETS EMPTIED AND CONVINCED THAT THE WATER IS COMING FROM THE BOTTOM OF THE UNIT, I TURNED IT OVER AND WATER CAME POURING OUT...
I would recommend that you manually fill the tank so you can watch it and see when it is completly full. If tank full sensor does not work then I would replace it. I think it is probably bad as it should not only tell you the tank is full it should also shut it off. Thank you.
Apr 29, 2011 | Soleus KY-34 Portable Air Conditioner
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
GE APN10AA Portable Air Conditioner Logo
223 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
