Question about Sherwood R-863 7.1 Channels Receiver
Had a power surge receiver keeps turning off it has power and the stand-by button is yellow when I turn the unit on it cycles for a few seconds then turns off and the yellow light comes back on
  • 2,272 Answers
Its the problem of internal power supply board.Due to power surge the internal circuit components have got short and stopped working.The circuit of the power supply board is not getting completed due to short component on the board.The board has to be checked with a meter to locate the faulty components.In some cases its just one or two minute ic components on the board gets short and replacement cost is very less but in some rare cases the power board needs replacement because cost of replacing component on board goes very much.
Also in some other cases it has been seen that power cables which goes into receiver gets loose or the cables gets short due to power Surge so the cables also needs to be checked for in-between short to clear the problem.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 03, 2010
I have a dish vip612 dvr which suddenly turned off and the cooling fan came on. I can't turn the unit on to do anything. If I shut off power and turn the power back on. the fan runs and the unit will not...
To whom it may concern,
You're likely either experiencing overheating or power cycling.
Put the receiver into a well circulated area, and let it cool down. If this does not alleviate your problem you will need a replacement box. Be sure to set up insurance for your account before you ask for a new box to be sent.
Feb 22, 2015 | DISH Network ViP 612
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Unit will not turn off
Sounds as if the control board took a power surge.
Jul 24, 2017 | Amcor CF14000 Portable Air Conditioner
The protection circuitry has been activated 3 times consecutively and as a safety precaution, capability to turn on the power is disabled.
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 20, 2012 | Yamaha RX-V671 7.1 Channel AV Receiver
How do I reset my yamaha rx-v671 receiver?
Yamaha RX V671 will not turn on anymore after a power outage
The protection mode has activated.
Reset the protection mode as follows and see what happens.
Apr 10, 2012 | Yamaha Audio Players & Recorders
I'm trying to install an older model alpine cd player in my boat. When I attached the red wire without attaching the yellow wire I don't get power to the unit, when I attached the red and yellow...
The red wire will be for constant power and the yellow wire will be for your accessories power. If you dont have accessories you will have to hook it up as you have said. To power the unit off, there should be a power button in the top left area of the unit. Hold that button down for a few seconds and it should turn off.
Aug 21, 2011 | Alpine CDE-7856 CD Player
UNIT WILL NOT TURN ON. IT WAS STORED WITHOUT TURNING THE UNIT OFF-POSSIBLY. I WAS ABLE TO PROGRAM A ROUTE-CANCELLED THE ROUTE ANDIT HAS NOT WORKED SINCE. I PRESSED THE RESET BUTTON
plug it in to a known good charger for a few hours, then press and hold the power button for up to ten seconds.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 08, 2010 | Magellan Roadmate 1200 Car GPS Receiver
I have a pioneer elite home theater and it's stuck in standby, i'm watching a movie then all the sudden (BOOM) everything turns off, and will not power back up.
Do you have a Home Theater Surge connected to it? If so, Turn the Surge unit off then back on, and your equipment should power back up. The surge will regain Main power but not enough to reset 110v just enough to keep your presets and settings. Hope that's the problem. If you don't have a surge, look on the front of the receiver for a secondary power switch that would be labeled "Main" etc. usually located below the standby or normal power switch. If it's not that, when you press the power button, does the unit "click" once, then two or three seconds later "click" again? That would be a chip, transformer, or IC chip and need to be serviced. If not that, post a reply with the model number and I can dig up some more info for you. Hope this helps
Jun 23, 2009 | Audio Players & Recorders
Stand-by light on, but receiver won't power up
Power supply problem. Most equipment today has remotes and the power supply has to remain on to sense the remotes signal.
But the actual receiver section does not get power until the remote says so or you hit the power on button on the unit. Internally the supply then feeds the device. Most likely cause is a power surge or storm.
See if the remote will power it up?
I presume this is still under warranty. If you don't have it plugged into a good surge supression outlet strip, Get one!
Mister Phil
Apr 05, 2008 | Audio Players & Recorders
Sherwood R-863 7.1 Channels Receiver Logo
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
