Question about Kidde KNCOBB Basic Carbon Monoxide Alarm with Electrochemical Sensor
Carbon Monoxide Alarm Beeps every 30 seconds 7 years old
    Sergeant:
    Champion:
  • 324 Answers
Likely the batteries are getting low, or you may need to replace it, otherwise i hope you dont have a poison gas in your home
Posted on Jul 03, 2010
4 beeps with pauses for 2 year old carbon monoxide detector
I'm pretty sure that indicates an alarm. The pattern is referred to as "temporal 4" which is the alarm pattern for CO. Either your device is in a bad place or there is an intermittent CO leak which is exceeding the ppm (parts per million) threshold for a given time period. The instructions for the device will tell you what that number is. If you have more than one of these, I would try swapping them to determine if the problen is with the device or the location. Good luck!
Apr 24, 2015 | Kidde Kiddie - Nighthawk Kn-cob-lcb-a Fire...
My camper has been in storage for 2 months. The carbon monoxide detector beeps every 30 seconds. I pushed the reset button and it does no longer beep. Is it still safe to use this detector?
Dale, My alarms beep like that to warn me of batteries needing replaced. What I do is hit the test button and ensure it sounds. I would still replace the battery(ies) and retest when you do.
Mar 07, 2015 | Kidde Carbon Monoxide Alarm Model Kncobb
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 09, 2012 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
How to fix detector
You don't mention how old the detector is. If it is more than 5 years old the detector may be beeping to indicate the end of its service life. A smoke detector can last much longer but carbon monoxide detectors have a limited life span. If putting in new batteries doesn't fix the problem then most likely you will need to replace it.
May 31, 2010 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
I have 7 year old smoke and carbon monoxide alarm...I have put a new replacement battery and detector is chirping every 15 seconds or so
Check the expiry date on this unit. The manufacturer recommends replacement usually after 5 to 7 years depending on the model.
You bought a Combo Gas/CO Detector for protection against the hazards of Gas and Carbon Monoxide poisoning. A new unit will give you the peace of mind you are looking for.
Visit my website for more information and view most Brands and Models of Carbon Monoxide and Combo Gas/CO Detectors.
Dec 20, 2009 | Kidde Nighthawk Combo Gas/co Detector
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Jun 03, 2009 | Kidde Nighthawk Combo Gas/co Detector
Kidde KNCOBB Basic Carbon Monoxide Alarm with Electrochemical Sensor Logo
558 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
