I can't delete my pictures of of my camera because they are protected.
  • kakima Jul 04, 2010
    What make and model camera? Many cameras have a button marked with a key or a lock to protect pictures. If yours has one, try pressing it and see whether a confirmation screen comes up.
    Also, SD and SDHC cards can be write-protected. If this is the case, take a look at the card. It will have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Audio Player... Master
  • 102,366 Answers
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Aug 09, 2010
My camera says internal memory full.How can I delete it?I have tried for a hour and I cannot delete it.The pictures that is.
Go to Menu.
Select a picture or multiple pictures you want to delete.
delete the pictures.
*make sure the file is not "protected" in which case you "un-protected the file and follow through the steps.
Note also that once you delete the pictures, they are un recoverable......you may consider backing up on the laptop or HDD before following through
Mar 21, 2015 | Cameras
Remove picture protection
Select the key icon from the Playback menu to protect/unprotect pictures. See page 33 of this manual: http://www.olympusamerica.com/files/oima_cckb/Stylus_1030_SW_Mju_1030_SW_Instruction_Manual_EN.pdf
Aug 16, 2013 | Olympus ? 1030SW Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
If i format the camera, will the labeled protected be erased?
Yes. The format operation will delete all pictures, protected or not. The protection only prevents accidental deletion via the delete button.
Sep 28, 2010 | Pentax Optio 33L Digital Camera
I can't delete protected pictures
That's the point of protecting pictures. You can remove the protection by reversing the procedure. Full details are in the "Protecting images and Sound Files from Deletion (Protect)" section of the manual (page 120 in my copy). If you need a manual, you can download one at
http://www.pentaximaging.com/files/manual/OptioWPi%20Manual_web.pdf
Sep 13, 2010 | Pentax OptioWPi Digital Camera
Pictures were protected for a temporary photo shoot now I would like to have them unprotected to delete. How does one go about deleting pictures from a Nikon D60?
To unprotect a picture, while viewing the picture press the protect button (marked with a key) to the right of the viewfinder. To delete the picture, press the delete button (marked with a trashcan) below the multiselector.
Jul 07, 2010 | Nikon D60 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Need to delete protected pictures
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
Apr 25, 2010 | Kodak Easyshare M753 Slim Digital Camera
Protected pictures
you have to unprotect them first... sometimes if you juts format the card (insert into your PC) this will delete protected files as well..
Sep 27, 2007 | Samsung Digimax S630 Digital Camera
16 people viewed this question
 Grubhead
Grubhead
