Question about Whirlpool LEB6300 Electric Dryer
A small box fell into the dryer cabinet, what can i do
  • Whirlpool Master
  • 8,220 Answers
You would have to unplug it and remove the rear cover. Take out the filter chute and get the box out before it damages the motor.
Repair manual
More here
Posted on Jul 03, 2010
DRYER MAKES NOISE WHEN DRYER TURNED ON SMALL PLASTIC PEICE FELL INTO DRYER LINT CATCHER
it may have worked its way into the b,lower. u have to remove cabinet and then remove blower cover and try to find it.
Aug 27, 2014 | Kenmore 500 6952 Dryer
How do you get top or front of cabinet off?
There are small clips between the top and the front cabinet. You need to use a bright light to find them, then use something like a small putty knife to go in between and release them. After that you will see how to take off the front. Hope this helps.
May 23, 2011 | GE DVL223EBWW Electric Dryer
How di i get access to the heater element on the Whirlpool model GEQ9800LW0
at the top of the lower small panel, use a putty knife to slide between the clips holding panel and pull panel out, bottom of panel has tabs holding to cabinet, you will see long heater box, element slides out
Sep 03, 2010 | Whirlpool GEW9200L Electric Dryer
Small toy accidently fell down dryer vent. What to do? Afraid to turn dryer on. Help
To get to where the toy fell on this unit is a little involved. Unplug unit. take out the lint filter and gently turn the machine upside down hoping the object will fall out if not you will need to take the back off the unit and loosen or remove the blower chute to get at the blower wheel and your missplaced object
Good luck...
Aug 10, 2010 | KitchenAid KGYS700LQ Gas Dryer
A small sock fell into the dryer lint trap. How can I get it out?\r\nThank you! Jan
You can try using a metal hanger to hook it and pull it out, but be sure to unplug the dryer before you try. There is also a small pick-up tool about 2 feet long you can buy at hardware stores for picking up small items in tight places. Good luck fishing!
May 18, 2010 | Whirlpool LER4634J Electric Dryer
Is there a problem with Maytag Neptune Dryer Drums. I have a customer who had one agitator fall off while doing laundry. I was called to make a vent repare and found the aluminum elbow attached to the...
i have repaired several of these simply locate the screw that fell out at the interior bottom of the cabinet and screw it back onto the baffle this is pretty common
Oct 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The belt fell off of the drum, i have the front off but i dont know where the disconnected pulley goes.
Unplug dryer or disconnect power.
Locate mounting slots in front of motor. (In some cabinets, there are two sets of slots for mounting the idler assembly. In this case, mount the idler assembly in the slots that line up under the grooves in the motor pulley.)
Install idler assembly into cabinet base by hooking mounting tab (A) into 1⁄4" wide mounting slots and setting mounting tabs (B) into the 3⁄16" wide mounting slot.
Make sure belt is around drum, with grooves down.
Route belt through the idler and around the motor pulley.
Sep 12, 2009 | Whirlpool Dryers
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Fins fell off tumbler on Whirlpool Ultimate II dryer
Remove 2 screws under the lint filter cover, then using a spatula or similar, prize apart the top cover from the cabinet, lift top cover and support it.Turn drum by hand until the drum baffles are at the top, and refasten the baffles one at a time.
Then lower cover down and press until it is closed, replace 2 screwa under lint cover.
Job done.
Plz rate this soution.Thanks.
Jan 01, 2009 | Whirlpool Dryers
How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Feb 05, 2008 | Dryers
Whirlpool LEB6300 Electric Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
