Question about Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
Hi, I have a Toshiba Satellite L300 Laptop thats shuts down, restarts or freezes whenever the ac plug is connected. Works fine on battery power and charges ok with laptop closed up or turned off. I have cleaned out the fan and heat sink hoping it was just an overheating problem but it did not help. I would appreciate any help. Thanks.
  • baiahmad Nov 09, 2012
    if a plug charger them reset my labtob toshiba l33
  • 942 Answers
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Posted on Jul 04, 2010
  • shoogs Jan 11, 2011
    hi solacity! i have the same issue on that same model. i tried another charger and it didn't work.
    if it's dual core, try to go in "safe mode" and disable one of the processors then restart. this worked only for a while though.
    a friend told me that it's the motherboard already. i took it to a computer repair center and they said the same thing - motherboard problem.
    Sergeant:
    Champion:
  • 256 Answers
Its a problem with mother board can be fixed only by a professional...
Posted on Jan 19, 2012
  • mohammed shaikh
    mohammed shaikh Jul 22, 2014
    i have solved this problem its a long procedure willhave to work alot on the motherboard and can be fixed
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
My toshiba laptop restarts randomly when it plugged.,and again restarts sometimes it will shut off .but no problem occurs when in batterry power.please help me to solve this problem.
Many models of Toshiba Satellite laptops have a capacitor called NEC/TOKIN Proadlizer which loses its capacitance with time and hence laptop freezes, shuts down or restarts when AC is plugged in. One needs to replace this cap as shown here:
http://gs138.photobucket.com/groups/q251/S1BXDWUERU/
Jun 09, 2011 | Toshiba Satellite Pro L300 Notebook
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
TOSHIBA SATELLITE PRO L300: PSLBDG : PROBLEMS: 1) Restarts automatically when i plug in the power cord. However works fine in Battery. 2) Shuts down when i try to install graphics driver after a clean...
Replace the AC Adapter, (ebay from £10.00).
Did it come with XP on it? Mine came with Vista and there are conflicts with XP and graphic adapters. There is no XP driver for the ATI adapter in mine.
Go online to Toshiba and download all of the updated drivers that you require. A user friendly system.
Dec 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 PC Notebook in battery the set is OK but when I connected ac power the set is hang on or restarted frequently
you should have your unit check professionally, as it can be cause by multiple problem.
1. laptop fan
2. memory problem
3. voltage problem.
either way, its best that you try to have it check thru the toshiba service center.
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
Rotating the volume wheel on my laptop freezes Windows
My toshiba satellite l300-1aq laptop is freezing within a minute of start up? How can I root cause the issue?
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
3,856 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
