Question about Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
Which tube takes water from pool to pump and which tube puts water back in on the model 633
  • 760 Answers
The outlet from the skimmer goes to the pump inlet (center) the pump outlet goes to the filter inlet. The filter inlet goes to the return to the pool.
Posted on Jul 04, 2010
How do i fix my saltwater pool its green?
it sounds like your chems are off, check you chlorine and PH, I go for a 3.0 to 5.0 on the chlorine side and 7.2 to 7.5 on ph,
Jul 29, 2014 | Intex 2500 GPH Filter Pump Krystal Clear...
How do i hook a vaccum up to my model 604 filter pump?
You should take your vacuum hose and plug it into the hole in the bottom of one of the skimmers. Fill the hose with water first or your pump will loose suction. I fill my hose by putting the head of the vacuum in the pool. Take the other end and hold it over a pool's discharge port (where the water comes back to the pool from the pump. When the air bubbles stop, put your hand over the end of the hose and move it to the skimmer and connect it.
That work for you?
Thanks fo your visit today.
Jan 30, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Intex 633 lost suction
I have seen a common problem when customers change / clean their filter is that put the DRY clean filter in the skimmer box or filter holder and sometimes it can cause an "air lock"
Just take your garden hose put in the intake outlet of your pool and turn that baby on....If you start seeing air bubbles on the discharge end of the line most likely that was your trouble.
If the problem still persist then at that time look into pump repair / replacement.
Good Luck!
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Water flow seems to restricted and the hose caves in
I FOUND ON MY INTEX POOL WHEN HAVING THE SAME TROUBLE IT HAD BLOCKAGE BETWEEN THE 1 1/4 HOSE ADAPTER ON THE INLET SIDE OF THE CONNECTION SUPPLYING THE PUMP AND THE BLUE FILTER SCREEN BEFORE THE OUTLET VALVE. MIGHT BE WORTH CHECKING THERE AS THE STRAINER BASKET WILL NOT CATCH ALL THE FINE DEBRIS. TAKE YOUR OUTLET HOSE OFF AND OPEN THE VALVE AND SEE IF IT IS RETRICTED.
Jul 01, 2010 | Intex Plunger Valve & Straniner Basket set...
Pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Jul 15, 2009 | Intex Plunger Valve & Straniner Basket set...
When vacuuming out iron, its blowing back into the pool
ok -
1. go to k-mart or pool shop and get yourself some pool socks.
Pool socks fit over your skimmer filter and will filter out smaller bits before going into your filter system - very good to use when 'vac'ing your pool when there are lots of particals in your pool.
2. If you have a sand filter system - you will have a control handle some where on your pipe work near your filter, which will have around some settings you can select with handle... like....> Normal, backwask, rinse, recirculat + others PLUS a pressure guage.
If you do have this sytem - 'vac' your pool on Normal - then when finished OR pressure builds - back wash - rinse - then back to normal.
sorry about spelling :)
Jul 06, 2009 | Intex Easy Set 2500 Gph Filter Swimming...
Handle broke off and its stuck in off position.
YOU CAN THEY ARE REMOVABLE IF YOU CAN ACCESS YOU MAY BE ABLE TO MOVE BY PULLING UP ON CENTER PLUNGER WHERE HANDLE ATTATCHES AND PUTTING IN TO FILTER POSITION
Jun 30, 2009 | Intex Plunger Valve & Straniner Basket set...
My krystal clear 636 pump sounds like its working but no water being pumped back into pool, any ideas my pump actually says model#636 on the side
IF WATER IS NOT TURNING IN PUMP BASKET IT IS YOUR IMPELLER AS THIS IS A COMMON PIECE THAT BREAKS ON THESE PUMPS MAKE SURE YOU HAVE ALL CONNECTIONS TIGHT AND ALL VALVES ARE OPEN TRY TAKING RETURN HOSE OFF THE POOL AND START TO SEE IF YOU GET FLOW YOU WILL HAVE TO PUT A PLUG IN RETURN SO WATER DOESNT LEAK OUT
Jun 28, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex filter model 633 with no instruction manual on how to set i
You can go to the website for Intex products and once you get to product section you can find and download a pdf manual
Jun 14, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Logo
196 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
