Question about Hoover F5899-910 SteamVac Vacuum
Motor started making a grinding sound and has a burn order. I found a site that sells parts such as motor assembly but I can not find a repair manual to provide disassembly instructions. It does look like this is a direct drive unit, that is no belts, at least none that a user can relace.Know of any repair manual sites? It is a Hoover F5899-900 SteamVac
    Top Expert:
  • Hoover Master
  • 12,962 Answers
Try a google search for the dilemma.
Posted on Sep 11, 2017
  • 184 Answers
SOURCE: replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Posted on Feb 10, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
Posted on May 15, 2008
reddevil6
  • 1673 Answers
SOURCE: I need a manual for my Hoover F5857-900 steamvac.
I tried hoover.com, none came up for this model.
We're sorry, we were not able to find any models when searching with "f5857-900". Please check the model number, and if you are still not able to find any results, contact our customer service department at 1.330.499.9499.
Posted on May 22, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 3 Answers
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
Turbine assembly is bad. Get part #23 here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Not to bad to put in.
You can also find them on Ebay cheaper.
Posted on Jul 01, 2008
I'm looking for CV1801 Vacuum Motor, Greator Toronto... Thanks
Hello There,
I've looked up your model vacuum cleaner, and it seems that I am able to still get this motor for your Eureka central vacuum cleaner. We're located in the United States, but we can certainly ship this to you.
Here's a picture of the diagram for you;
We sell the genuine Eureka motor for $199.00, however you may save substantially on this motor by purchasing it under the Lamb Electric name. The motors are identical, and Lamb actually makes this motor for Electrolux, and sells the replacement parts for MUCH less money they Electrolux. We sell the motor under the Lamb name for $119. I went ahead and added this part to our site so you could place your order if you wanted to. I don't have it in stock today, but my parts distributor is showing 3 in stock, so we can easily have your order shipped out within 2-4 business days.
Here's the link to the Eureka CV1801 Central Vacuum Cleaner motor, Part number 54586;
http://www.govacuum.com/10661-Eureka-Central-Vacuum-Cleaner-Suction-Motor-Assembly-Part-54586-.aspx
Hopefully this was helpful to you. I've also left you a link below to the parts diagram of your vacuum cleaner, in case you need some visual help to see how it comes apart. If you found this repair to be helpful, please be so kind and rate the repair helpful, or leave feedback for me. I really do appreciate it, and this also helps people with the same question find the answers easier. If you have any questions, please feel free to email me at chris (dot) jones (at) govacuum (dot) com.
Full Size Schematic in .pdf form:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/eureka-cv1801-central-vacuum-cleaner-part-diagram.pdf
Thanks so much,
Chris Jones
GoVacuum.com
Jan 06, 2011 | Eureka CV1801 Bagged Vacuum
Th end of the shaft that come from the motor is worn out, and won't hold the belt well. How do I change it?
Thanks for the clarification. I have never seen this problem previously in a Kirby. I wonder if the belt keeps sliding off because it's been stretched out? After about 1-2 years, the belts on the Kirby will stretch out to a point where there can possibly slide off the motor shaft. Have you tried just replacing the belt on the unit first?
If you're sure that it's not the belt that may be stretched out, and you'd like to replace the motor shaft, you certainly may do this. The only problem with this is the motor shaft is not sold by itself as a separate part. The only way to purchase this motor shaft is to purchase the entire fan assembly, which includes a new fan, and the hardware necessary on the fan assembly.
Here's a parts diagram that shows you the motor shaft is sold only in a completely assembly:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/kirby-generation-parts-diagram.pdf
If you haven't already purchased the motor shaft, here's a direct link to the motor shaft and fan assembly on our website:
Kirby Generation Fan Assembly With Motor Shaft and Hardware
In terms of installing it, we've actually recorded a video repair on how to replace the fan assembly, which involves removing the motor shaft in order to get the fan off. Since you have to purchase the fan assembly anyways in order get the motor shaft, you may want to go ahead and replace your fan assembly at this time also. Even though your fan may not be broken, on Kirby's the fans can become coated with dirt and fine dust, which can sometimes lead to the Kirby exhausting a bad smell. If you'd rather not replace the fan, you may remove the motor shaft without disassembling the entire machine, you'll just need to secure the fan somehow so that the fan doesn't spin while you're using a nail to turn the motor shaft off.
Anyways, here's the video repair that we recorded. I hope that this helps you. If you found this helpful, please kindly rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair. This is really what keeps Fixya repair professionals continue to give free repairs online.
Here's Part 1 of the video:
Here's Part 2 on Replacing the motor shaft and fan:
If you have any follow up questions, I'd be more then happy to answer them for you, please just add another comment here on the repair page, and I'll be more then happy to answer any follow up questions that you have. Thanks again for rating the repair, I greatly appreciate this.
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
Motor is sparking and smells like burning rubber. When it first happened I thought the vacuum had something jamming the beater bar. That was the smell it had, like when the belt gets burned. But when...
from sound and description most possible is motor is burnt up sparks usually mean metal on metal either bearing or bushings went on motor if u can jiggle the shaft thats bearing if u rotate the shaft by hand and feel and or hear rough grinding the brushes are damaged and the (windings)are also would need to replace motor oreck has a costumer service 800 989 3535 number give them a call not always but some times they will ship a replacement part for free
Nov 22, 2009 | Oreck Vacuums
Vacuumed water - won't work
it sounds like the motor overload is cutting out.
it should automatically reset in time.
  • try removing the motor from the vacuum.
  • jump the motor. (power directly to the motor leads) be careful doing this! because once you plug it the motor will jump...keep your fingers from moving parts.
  • With the motor running, you will want to inspect the commutator -(where the carbon brushes push against)
  • if a blue spark is large and wrapping around the commutator then you will need to replace the brushes to begin with...in worse cases the armatures commutator would have to be cleaned with emery paper.... or armature should be replace. i think vacuum motors sell as a assembly...depending on what type of vacuum you have it might be better just buying a new one.
Oct 07, 2009 | Vacuums
Hello. I took the sole plate of to clean the brushes on my dyson dc14 however the brush part came out and i put it back in but since then whenever i switch it over to carpet setting it makes this really...
You really need to take the sole plate back off and make sure the belt is running exactly where it's supposed to go and not looped over a piece of plastic or anything. More important is that you make sure the ends of the brush are seated properly and the bearings the brush is mounted to are clean and rotate freely. Look at each component and make sure they are assembled perfectly. Make sure a plastic ring or piece that goes on the end of the brush didn't get dropped under a piece of furniture and you forgot about it. If the problem keeps happening, take the brush and belt back out and carefully turn the machine on to see if it makes the sound. If it doesn't make the sound with the brush out, the problem is with the brush assembly. If it does make the sound, the clutch that turn the brush on and off is damaged and needs to be replaced. You can order a new clutch assembly and replace it without much trouble. They want you to think you can switch between floor and carpet settings all the time but it's really really stressful on that clutch to switch between settings with the motor running. Think about how powerful that motor is. Think about the poor unassuming brush assembly being jerked to life by that powerful motor running at full speed. I've seen that destroy a clutch in about two years. Anyway, it's much better for the life of your dyson to turn the motor off when you switch to carpet mode (when you turn the brushes on). You probably don't have to bother turning off the motor when turning the brushes off, or switching to bare floor mode, because it's not that stressful on the mechanism to just disengage the running motor.
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
Siemens/Bosch Vacuum cleaner
I ordered both a motor and belt by calling the Bosch service number in the manual and installed them myself, but quickly they failed again, the nylon cogs burned off (wish I could just get the cog wheel, but they have to sell you the whole motor). I bought a second Vax branded machine, which worked okay at first but now it constantly needs to be emptied for suction. Now I'm hoping to swap the bottom of my new machine with the top of my Bosch which doesn't have the suction problem. Good luck. Susan
Nov 09, 2008 | Vacuums
Loud noise
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Roomba
Mine did the same thing. I'm going to send it back for a warranty repair.
Dec 23, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Hoover F5899-910 SteamVac Vacuum Logo
54 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
