Question about Radio Shack Pro-2096 Base Scanner
800 MHz frequency Mode problem
Scanner will accept 800 MHz frequencies. The bank they are put into will scan (bank #2 ) but you never hear anything unless you keep it on one frequency ( one channel ) at a time by manually putting it there. The Mode being used is (MO) Motorola / APCO-25 Trunking Mode. When that frequency opens up and it talks the MO mode changes to +DG. If you change channels and go back to the first one it's back to MO. How can I get it to scan with all these 800 MHz frequencies and have them open up and talk without manually making it stay on just one ? Just sign me as frustrated. Using the PRO-2096 Digital Trunking Scanner. Thanks, KA1QFV
  • Radio Shack Expert
  • 509 Answers
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Posted on Aug 10, 2010
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
Cant get any frequencies to program
hi select a bank ,Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears. 2. Use the number keys and to enter the frequency (including the decimal point) you want to store. 3. Press E to store the frequency into the channel. Notes: • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency. • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475. • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning
Mar 18, 2011 | Uniden BC72XLT Handheld Scanner
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
I cannot figure out how to program my scanner to the fire frequency.
To program any known frequency into your BC72XLT, power the scanner ON, and then:
1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
Notes:
• When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
• If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://uniden.com/pdf/BC72XLTom.pdf
BillB
Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Frequency Coverage:
For a comprehensive database of active frequencies in your area, visit
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Feb 01, 2009 | Radio Communications
BC72XLT program/scanning problems
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
BC72XLT
Here is the directions to store frequencies in your scanner:
Storing Known Frequencies
Into Channels
to store.
Notes:
Operation 2 seconds after the end of a transmission before
accept.
Dean
Rollin CBs
Feb 19, 2008 | Uniden BC72XLT Handheld Scanner
Radio Shack Pro-2096 Base Scanner Logo
458 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
