Question about Whirlpool Dishwashers
Whirlpool ADG7540 integrated dishwasher - error code 6 flashes - can you tell me what this means please and is it repairable? thanks
My integrated whirlpool dishwasher is not spraying from the top but is letting water in from the bottom and draining okay
Posted on Oct 14, 2009
Whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • Nov 05, 2011 | Whirlpool 24 in. ADG7540 Built-in...
    Whirlpool ADG7540 approx 4 years old (maybe a bit older) I have ran diagnositic check and the start light flashes 4 times stops briefly then flashes 4 times again over and over along with a continuous...
    Yikes, we have just identified this exact same problem tonight. If you've had any success with fixing it, we would sure appreciate hearing how. Best of luck with your machine
    Mar 03, 2011 | Whirlpool 24 in. ADG7540 Built-in...
    Flashing lights on my dishwasher
    Have you disconnected it from the socket to try a reset? If not firstly try this, if flashing continues, please hold down the on/off button continuously for about 5-10 seconds during that time it will beep or flash but keep hold until this master resets the dishwasher, then try a normal cycle, this should then resolve this, unless the PCB board has gone wrong, in which case I would contact the maker of it is still under warrentee, if no warrentee then call a local repair person, most offer a free quote if you ask for one... I hope this helps....
    Feb 21, 2018 | Dishwashers
    Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
    call for service to change the outer panel.it takes about 15min.
    Feb 24, 2010 | Whirlpool 24 in. ADG7540 Built-in...
    Start light flashes 6 times
    6 'start' led blinks indicates
    WATER TAP CLOSED
    Water walve is switched on but flow meter sends no impulses or sends less tan 10
    impulses in 10 seconds and the water indicator is off (empty)
    posible reasons:
    water tap closed
    water inlet hose closed
    water inlet valve defective
    flow meter defective
    remember to unplug it from power if any repair is done
    Best regards and good luck
    Oct 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
    Dishwasher won't finish cycle
    it means that your heater or board are bad
    Aug 20, 2009 | Dishwashers
    How do I take the intergrated door of a busted whirlpool ADG 7540
    open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
    Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
    My whirlpool ADG 7540/1 doesn't heat up properly when washing, sometimes "lukewarm", sometimes a bit warmer still but not the 65 c of the programmed wash. Any ideas?
    I have a Whirpool ADG7540/1 integrated dishwasher that goes straight to rinse programme, it is 6 years old, has it come to the end of its day or is there someone out there that can help? Sheelagh Fed up (Pontypridd)
    Apr 21, 2008 | Whirlpool Dishwashers
    No manual
    http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
    Select your dishwasher type and the language.
    Feb 27, 2008 | Whirlpool 24 in. ADG7540 Built-in...
    Dishwashers Logo
    279 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
