Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
We purchased the 24' by 52" intex pool with saltwater filtration system. We use well water that is taken out of the ground by a windmill. We depend on the wind for the water, so it has taken a month to fill the pool. The water is green and there is debris at the bottom of the pool. Is it OK to put the salt in and turn the pump on, now that it is full? Should we give it a couple of days or should we go ahead and shock it? Thanks, Patricia Tieken rtiekenww@hotmail.com
  • rtieken647 Jul 07, 2010
    Thanks, We already added it because this sight said it would notify us by e-mail when we received an answer. We never got the e-mail.
  • 532 Answers
Yes, you can put the salt in and turn the pump on.
Thanks.
Posted on Jul 03, 2010
I have a Intex above ground Pool 18 feet by 9 and 52 inches deep. How do I over winter this pool?
no you cant keep an above ground pool full water unless you live in a warm climate area that dont feeze
Oct 19, 2014 | Intex 18 X 52 Ultra Frame Pool Set with...
Can intex krystal clear saltwater system be used on 12000 gal. above ground pool?
personally, my opinion is no. if you have a real pool, get a real salt system.
Sep 08, 2014 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System For Above Ground Saltwater Pool won't turn on
Usualy if it is some years the ball bearing on the motor shaft are rusty and if you can desasemble and use a UD40 lubricant or similar it can be fixed, or replace the bearing. One more posible case is the starting capacitor if it replaced can run the motor again.
Jun 05, 2012 | Intex Automatic Salt Water System for ...
I have an above ground pool 18' round 52" deep. I purchased the intex saltwater system. I have had it run everyday for 8hrs a day and the ph is high and reads no chlorine. What to do?
Salt generating systems cuase pH to rise over time so you generator appears to have been working. What is the salt level in the water? Perhaps your pool is low hence no more chlorine generation.
Aug 27, 2010 | Intex Automatic Salt Water System for ...
If my pool has an algae problem now . can i convert to a saltwater filtration system w/o draining the pool ?
You need to rid the pool from algee. When you say saltwater filtration do you mean a chlorene generator? It generates chlorene from the sodium chloride that you maintain in pool. This still means you need chlorene to kill the algee. Shock the pool with chlorene shock. After allowing the pump filter to mix, let stand ovenight. Vacuum green slime from bottom to waste. Your pool supplier can help you . Kill the algee then start up chlorene generator.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
Cloudy water after running system for 15 hours
yes ... do you have filter media insyalled and the proper amount of salt installed?
Jul 03, 2010 | Intex Automatic Salt Water System for ...
We recently purchased the intex saltwater system for our above ground pool. We read all the instructions and followed them however our water is still cloudy and a light shade of green. what can we do
You need a sequestering agent to remove the metal from your water ... let the chlorine go to nothing ... put in some 'metal out' or similar according to the instructions on the container ... then start again with the chlorine.
Chlorine and copper and/or iron = green water
Thanks for your interest in FixYa.com
Jun 25, 2010 | Intex Automatic Salt Water System for ...
Hose hook ups
If you look at the chlorinator you'll see an arrow pointing in the direction of the flow. Basically the water coming out of the pool should be going through the filter tower first and then through the chlorinator and ultimately back into the pool.
Jun 16, 2010 | Intex Automatic Salt Water System for ...
Please give me the start up directions for the intex saltwater pool system
hold arrow down till beep hold arrow up till beep press up arrow to desired amount of hours then hold both arrows down till beep to lock in schedule. It will run that schedule every day.
Jun 06, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
