Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Bad lower oven element
How is the lower oven element removed from viking 36 inch dual feul range?
  • Viking Master
  • 8,220 Answers
Posted on Jul 03, 2010
Need part number for oven element
Try a company called e spares on the internet give them the part no and they may have one
Mar 22, 2014 | Viking VDSC365-6B Dual Fuel (Electric and...
My viking oven door has literally fallen off the left hand side hinge - is this a diy FIX?
The door slides onto the two hinges and is held in place with two gravity operated latches. I'm not sure of the condition of your range but it sounds like the door was forced or lifted rapidly allowing the one side to release. The only solution I know of is to remove the other side and reinstall. The hinges have multiple locking positions so the next time you are cleaning your oven, open the door about 8 inches, find the small latches in the door hinge groove, and hold them upwards as you lift the door towards yourself.
The hinges should remain slightly opened. For installation, lower the door onto the hinge posts and pull it outwards slightly.
Oct 27, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
They just installed a kitchenaid 36 inch KDRP467K
Hello- 'They' should have re-checked bus block connections for cord. Element won't work with one leg. If connections look good, check element connections and then power connection for element at board. If it still doesn't work, check resistance of element. Should be around 13ohms. This is the troubleshoot sequence for solution to your problem, but should be under warranty for first year. A piece of advice- avoid the 'self-clean' function. This feature is called 'self-destruct' by techs. Please acknowledge this post if helpful. Have more info if needed. Thanks-  Ed
Mar 23, 2010 | KitchenAid Kitchen Ranges
Jenn-air ww30430w dual oven, lower oven, lower element not heating, upper broil element working fine
Most likely a bad element. Turn off the power to the oven. Remove the racks.
Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
A new element will correct your problem.
If the element reads as good you have a wiring problem or a bad control.
Jan 03, 2010 | Ovens
I have a Viking Dual Fuel Range. The large oven
if your elements are exposed and not hidden, check to see is there is food particles may be baked on the element, you might need a new element, cheap to purchase yourself and install if handy
Sep 03, 2009 | Kitchen Ranges
Replacing heating element in oven-connecting wires fell back in
hey sorry about that,as a repair man i hold on to those babies like crazy.almost all ovens i worked on [its many]the rear wall dose not come apart.if yours dose great go that way.but other wise yes you have to go thru the back.i would try fishing abit more before i pulled it out if was me.God bless,tom
Jan 02, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven will not work
It sounds like the Thermostat is defective.
Element can be removed from the front of the unit, it does not need to be pulled
Oct 27, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
219 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
