Question about Mitsubishi WS-55511 55" Rear Projection Television
Rapid flashing green light just above power button and No reset
TV will not turn on and has a rapid flashing green light near the power button
  • 10,594 Answers
Hi, If its Mitsubishi WS-55511 tv as model shown in question title then it would be problem of few leaky electrolytic capacitors in DM module that need to be replaced all of them.
DM module is located on left side if you see tv from its rear, its next to connection board.
If you are not familiar with soldering parts in circuit board then local tv repair shop will help you to fix the tv.
Let me know if you have additional question.
Thanks.
Posted on Jul 03, 2010
Apple tv unit ,rapid falshing of power light
Hi Doug
Take a look here for what the lights mean:
Apple TV About the status light
Andrew
Jan 07, 2014 | Computers & Internet
Constant flashing red light near on/off switch
i think it is the power supply board problem
Nov 05, 2013 | Televison & Video
How do i reset the projection lamp timer?
Hello
Press the "Power" button on the TV remote to turn the TV on. Press the "Display" key. Press "5," followed by the "Vol+" key, followed by the "Power" button. Wait for the service menu screen to appear on the screen. This could take anywhere from a couple of seconds up to a minute or two.
Press the "Jump" key three times in rapid succession. Press "2" nine times in rapid succession
Press "3" once, followed by the "Mute" key, followed by the "Enter" key. Wait as the screen flashes momentarily.
Press the "Power" button on the TV to exit the "Service menu" and turn the TV off.
Mar 15, 2011 | Televison & Video
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Had power outage and after hitting reset button green light blink
Hard to say without looking and sniffing!
But if you suspect that it is and it is likely, you may be able to get it repaired on your insurance policy. It should be covered under FUSION
Dont mention the lightning but check your policy. Then get the repair guy to write fusion problem on the receipt and submit for claim.
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My wd-52525 dlp tv has a flashing green timer light(rapid).. TV does not start even after reset, unplug ect. This started after powerloss in house. HELP??? ANYONE>
Replace the capacitors on the power board. You get the V26 DLP DM repaor kit at the following link which has the capacitors plus detailed instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Televison & Video
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
252 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
