Question about GE 106591 Coffee Maker
Water wont heat. Warmer has no heat but light is on
  • 532 Answers
Hello, One of the wires soldered to the underside of the warming plate had fell off due to poor soldering.The warming plate and the warning light are connected together with piggy back connectors so that is why the light is on even when the warmer is cold. Bye
Posted on Jul 03, 2010
Add water light comes on when it is full
Try using warmer water. At 113 degrees our 2.0 finally admitted that the reservoir did in fact have enough water to operate. I filled the reservoir half full of drinking water and then heated other water in a water kettle. Just before it boiled I began pouring it in the reservoir until the Max level. To my delight when I pushed the continue button this time it worked. Customer Service had said to use luke warm/ room temperature water. For our Keurig, the water needed to be at least 113 degrees. Hope this helps.
Sep 06, 2014 | Keurig B60 Coffee Maker
Heater not working
if you set for a temp warmer than water is now if it wont heat up see if menu shows its calling for heat if not temp sensor if so sounds like bad heating element also is recirculation pump runnig and are your filters clean?
Apr 03, 2014 | Pool & Spa
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
The element heated up without the dishwasher being turned on. There was no water in the dishwasher but a lot of heat. Bake the food onto the dishes. The only reason I checked it was because there was a...
It sounds like the plate warmer setting was activated or the timer may have been manually advanced to the heated dry portion of the cycle.
Jun 30, 2011 | Dishwashers
Can i unhook the electricity to the cup warmer tray to save power
I think that the heating to the cup warmer comes from the water boiler which is place underneath so the heat is produced anyway.
Please remember to vote for this answer thanks
Feb 18, 2010 | DeLonghi EAM3400 Espresso Machine
New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Jan 10, 2009 | Warmrails & Satin Nickel Towel Warmer &...
8543 not working
CHECK THE BLACK WIRE COMING OFF THE BOTTOM TERMINAL OF THERMOSTAT FOR VOLTAGE, IT SUPPLIES POWER FOR THE WARMER SWITCHES. THE 'READY TO BREW' LIGHT IS PROBABLY A BAD BULB.
Oct 12, 2008 | Bloomfield 8543 Coffee Maker
Oven wont heat
check the outlet for 220 and the power cord
May 25, 2008 | Ovens
Cold water
The law of thermodynamics states that heat travels from a hotter object to a colder object. In a refrigerator the temperature is colder and there for the heat leaves the water and into the colder air surrounding it. However nothing happens in a flash and the movement of the heat from the water takes time. The time is related to the volume being cooled. If to much water is being drawn it will be warmer.
May 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Coffee pot
I am having the identical probem, I plug it in, it starts to heat, but no brewing. I have removed the lid and the water pan underneath, and looked into the opening. When heating, the voltage on the main heater is 110 volts. It stars to steam, then the unit switches off.I think that for some reason,it's not allowing the temp. to rise to the boiling point. Anybody have any ideas? I'll check on that one way valve in the meantime.
May 30, 2007 | Bunn VPR Coffee Maker
GE 106591 Coffee Maker Logo
176 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Tom Chichester
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
