530 Authentication required means that your e-mail service needs an authentication.
All you have to do is to change the Outgoing server smtp. Usually, email clients uses port 25 as the outgoing port, and that is by default. You can change it to 465 or 587.
Here's how:
1. Open your Outlook 2007 > Tools > Account settings.
2. Double-click your account > click on "More Settings" button.
3. Go to the "Advanced" tab > change the port from 25 to 465.
4. If port 465 did not work, click the drop-down menu for the "use the following type of encrypted connection:", and select SSL
5. Click OK > Next > Finish.
6. Try to send a test mail.
If that did not work, change the smtp from 465 to 587 and set the encryption to "None".
Thank you and good luck!
Thanks but it did not work. When I changed it to 465, it said, connection to server interrupted. I tried the other 587 as well, no luck. I am soooo frustrated.
Kindly try to change the outgoing smtp from 587 to 2525. Make sure that the encryption is set to None.
The error "connection was interrupted" has nothing to do with your email. It has something to do with the internet connection. The internet connection is a bit intermittent, that's why you're getting this error.
If port 2525 will not work, set the encryption to SSL.
Thank you!
Okay, can you send me your complete email address (the one associated with Outlook 2007).
I will check the outgoing mail server. There could be a possibility that the ports are properly setup, but the outgoing server is incorrect. You have to make sure that you type your complete email address in the user name field. Then try to re-type your e-mail password. Password is a case sensitive.
Thanks.
Not solved yet, working on it
This did not work but with changing it somewhat, it did come up with a different error, connection to server interrupted. Maybe that can be fixed.
Please help me to fix this problem, I cannot even send you an email.
Okay, I did everything you said and now it is saying that outlook cannot connect to your outgoing email server. Contact service provider.
