Question about Panasonic CT-27SC13 27" TV
Lost picture went to turn up volumn with button on set,didn't lose picture,it went crazy.wavy swirls,grays and purple unwatchable.every channel the same.audio ok.set is only 3-4 years old
  • 975 Answers
Check for any DRY SOLDER in the pc board , if it still doing the same thing , then replace the VERTICAL OUTPUT IC , and please get the original replacement , generic part no guaranteed that will work 100%
Posted on Apr 17, 2008
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
Dec 27, 2013 | Computers & Internet
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
Some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Jun 07, 2010 | Vizio L32 32 in. LCD HDTV
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
Distorted purple image when camera is switched on
That is weird, maybe try to reset it by taking the batteries out and then putting them back in and starting it from scratch. Electronic problems....yikes.
Dec 09, 2009 | Fuji FinePix S5000 Digital Camera
Rca model p61960 projection tv dead
More likely a bad flyback transformer......T.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Jan 27, 2008 | ESA ET413E 13" TV
Menu going crazy on the screen!
it sound as the menu button is staked, is a easy job for a tech, but dificult one for regular people, better get a tech and let him know that you know the problem is the menu button, thas gonna help with the price off the repair...good luck
Aug 06, 2006 | GE 46GW 948 46" Rear Projection Television
Panasonic CT-27SC13 27" TV Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
