Question about Epson Stylus 2200 InkJet Photo Printer
Paper won't feed. starts then red light comes on paper button.
  • 53 Answers
Is your paper pushed in far enough, or is it jamed. eather pul lpaper out, or push paper in. don,t worry about it
Posted on Jul 03, 2010
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
I set up my own wireless network and now my printer will not communicate with my laptop.WIFI light flashes red. Have tried everything to reconnect. Lexmark Z2420.
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Jul 29, 2010 | Lexmark Z2420 Printer
Printer shows a red light for paper. It will not
Remove the paper tray and clean the feed roller with alcohol or water.
Oct 04, 2009 | Brother HL-2040 Laser Printer
Printer stopped working Epson C86 and red middle light button on
The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
Apr 10, 2009 | Epson Stylus C86 InkJet Printer
Steady red light feed paper button
your printer needs to be reset put this in google scc download it and that should work
Nov 23, 2008 | Epson Stylus Photo 1290 InkJet Printer
The paper only feeds part way and then stops. Red light comes on
Following a suggestion on another post, I tilted my printer so it is at a slight angle backwards, higher at the front. So far this has worked.....
Nov 12, 2008 | Samsung ML 2010 Laser Printer
Both red lights come
this may mean the waste pads are full and needs to be rese with software has i cant give you my email to give you the software messge me on here and i will try and help you
Apr 21, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus 2200 InkJet Photo Printer Logo
89 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
