Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak 2100 Heater wont fire unless the pressure switch is jumped. Replaced pressure switch and still same issue. Whats next?
  • 760 Answers
Usually when these are plumbed in there is a bypass valve allowing you to run your filter and system withouth the heater. There would be a valve before and after the heater (which should be open) and a valve connecting the inlet and outlets ( this valve should be closed) Make sure you're not "bypassing: most of the water flow. If this isn't the problem then try the following: This switch is designed to prove flow. If you don't have enough flow to cause enough back pressure to make switch, then it assumes you dont' have flow. First make sure your filter is clean, and your skimmer and pump baskets are clean so you're pumping maximum volume of water. If these are clean have an assistant or two hold their hands on your discharge ports in the pool. If this backpressure cause the switch to close then you might try slightly smaller return jets to your pool. You can not the pressure on your filter and compare it to the pressure setting on the switch.
Posted on Jul 04, 2010
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
Raypak p-r405a PRS message. tried adjusting pressure switch, no change
clean out pump basket, backwash filter for starters. jump the pressure switch if nothing changes. if burners fire then replace the pressure switch
Dec 06, 2012 | Raypak Pool & Spa
Raypak 2100 turning off and on
check gas pressure if ok check flame sensor if ok check pressure switch make sure making contact or loose wires to pressure switch
Oct 03, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Screen has prs clean filter screen and service flashing
pressure switch is open. clean out pump basket and backwash the filter.... if you have proper water flow, jump the pressure switch....if heater fires up replace the pressure switch
Jun 11, 2011 | Raypak RP2100 DIGITAL POOL HEATER R206...
The pilot will light but the burnner won't ignite. A pool guy said to turn the theromstate control real slow to a higher tempature and then the burnner will ignite. That worked a few times but now that has...
More likly you have a dirty filter. Or a plug in a line. Test this by jumping your pressure switch. You can also check thr roll out switch the wire that rung along the fire wall just above the burners. It will have a black cover about two inches long on it that has a switch that is cased in wax if the fire rolls out the front of the cabnet the wax melts and shuts the heater down. Check this by jumping also. I hope this helps.
Sep 02, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
360 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
