Question about Home
My triton aquasensation AS2000T power shower has stopped working. Makes noise as if motor is working but no flow. took cover off and found quite a lot of Carbon? on inside. Is this likely to be the solenoid valve or the pump and how can I tell?
I have had a similar problem which is down to the motor top bearing which has tightened up. I have recovered this 2 or 3 times now over the last couple of years by a total overhaul after strip down. By far the easiest way of solving without a total dis assembly would be a few drops of '3in1' at the very top outside of the motor assy (the black plastic looking part. Not the commutator. The motor might need to be turned back and forth a few times by hand to get the oil 'in'. It should then run freely.
Posted on Oct 20, 2010
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Triton 300si wireless shower problem - Shower motor is working but the low presure sign is flashing but all other water pressure is normal. Water was coming out but going hot and cold but has now stopped...
check inlet water first for consistency, if flow is fine and pump is working correctly, then check non-return valve on your pump outlet.
if these check correctly, check electrical side, if flow to heating element is constant, if that is interrupted, i am afraid that motherboard on your unit may be faulty,
you have then only two choices, dismantle the unit and check all wiring and component or get unit to repair centre or call plumber... or eventually replace unit by yourself.
please be aware that mendling in electrical circuit is dangerous! fully disconnect from power before you remove the covers!!
please be aware that before you attempt to repair electrical or plumbing gear you need to cut off power or water supply to the unit in full, they do not mix very well... :-)
Jul 29, 2010 | Home
How do I open a Triton shower box ?
there are usually screws on the top and the bottom of the shower unit holding the front cover on.
Apr 11, 2010 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Triton shower noise in motor
May have calcium buildup in the system from hard water. See if you can get lime away inside the units passages for a short soak then lube it with a silicone based lubricant or vasline.
Sep 23, 2009 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Home Logo
849 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
