Question about Husqvarna 23HP VTwin Hydrostatic 48" Cut Riding Mower
Mower lift cover popped off fender
Simple thing right! last week after using the machine I wased deck and under carriage. The top plate of the lift assembly pooped out of position and I can't figure out how to get it off to re-install. Can't fit it on my truck, and don't want expensive time consuming repair for susc a small thing. Don't want to use duct tape and bailing twine!!
Can anyone tell me how it goes on and off the fender assembly?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Take a look at this parts diagram (if it's not the right one, search partstree.com for the correct one). The cover plate for the lift lever gets captured inside the console deck lift panel (#283 on the diagram). Than panel is held to the fender with four retaining clips (#282). If the cover plate is just wonky, take off the clips, lift the panel and reassemble correctly. If the whole panel has lifted up and the clips are lost, you'll have to buy replacements. You could ordering them but you might find some clips that work if you have a local hardware store that has a good stock of small hardware parts. Hope this helped, if so please rate my answer, thanks!
Posted on Jul 05, 2010
Testimonial: "Thanks, I was able to pry it back in place with greased screw driver head. Your link is a good one so I'll keep it for next time Thanks"
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 | Worx Garden
How do i remove the rear fender on 2012 nightster
Secure the motorcycle upright on a suitable lift and then remove the main fuse and the seat. Lift the motorcycle just sufficiently to remove pressure on the shock absorber bolts and remove the lower ones and then lift the motorcycle higher to increase clearance between the tire and the fender.THEN unplug license plate lamp connector and the right rear lighting harness connector which has a brown band on the harness near the connector and then also unplug left rear harness connector and carefully pull both rear lighting harnesses and the license plate lamp harness through the holes in the fender and free all of the harnesses from the fender harness clips and remove rear turn signal stalk nuts from under the fender on both sides. THEN loosen and remove the front fender support screw and washer and nut and then the rear fender support screw with washer and washer and nut plates if present and remove the screw and washer attaching the rear fender brace. If necessary remove license plate lamp module harness from the upper harness clips on the left side of the inner and separate the license plate bracket from the rear fender brace. THEN remove the rear fender strut covers and the attached turn signal assemblies from the fender struts and pull the turn signal harnesses through the fender holes and struts as the strut covers are taken off. THEN put suitable materials between each fender strut and fender to protect the paint. It might be best to have someone assist and hold the fender at appropriate times. THEN you can remove the seat post with its washer and screw.
Jul 04, 2014 | 2011 Harley Davidson XL 1200N Nightster
How do i remove rear fender on nightster
Secure the motorcycle upright on a suitable lift and then remove the main fuse and the seat. Lift the motorcycle just sufficiently to remove pressure on the shock absorber bolts and remove the lower ones and then lift the motorcycle higher to increase clearance between the tire and the fender.THEN unplug license plate lamp connector and the right rear lighting harness connector which has a brown band on the harness near the connector and then also unplug left rear harness connector and carefully pull both rear lighting harnesses and the license plate lamp harness through the holes in the fender and free all of the harnesses from the fender harness clips and remove rear turn signal stalk nuts from under the fender on both sides. THEN loosen and remove the front fender support screw and washer and nut and then the rear fender support screw with washer and washer and nut plates if present and remove the screw and washer attaching the rear fender brace. If necessary remove license plate lamp module harness from the upper harness clips on the left side of the inner and separate the license plate bracket from the rear fender brace. THEN remove the rear fender strut covers and the attached turn signal assemblies from the fender struts and pull the turn signal harnesses through the fender holes and struts as the strut covers are taken off. THEN put suitable materials between each fender strut and fender to protect the paint. It might be best to have someone assist and hold the fender at appropriate times. THENyou can remove the seat post with its washer and screw.
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
How do you open case to clean inside of glass
Lock the carriage first! Remove the two medium-sized Phillips screws under the hinge and the small one over the small plastic cover plate. Remove that cover plate. Slide the top tray (glass and cover) off the frame by pulling laterally in the direction of the hinge. It will snap out if you work on it. Clean the glass. Slide tray back in and seat it securely. Put the large screws in to hold the carriage. You won't be able to screw them in if the cover isn't seated right. Now make sure the 5-conductor ribbon cable that is under the small plastic cover plate gets stuck back in the socket. You just push it into the tiny black socket. I think that tells the scanner what's going on with the cover. Then reinstall the cover plate. Now you should be good to go! Don't forget to unlock the carriage.
Aug 27, 2010 | Canon CanoScan 3200F Flatbed Scanner
How to replace drive belt on john deere model 345
- remove deck
- remove seat and rear fenders
- pry off deck adjusting knob
- remove F/R pedals
- remove floor plate
- use jackstands to prop up entire right side of tractor
- remove (2) screws holding fuel lines on side of frame
- lift out gas tank, set alongside left side of tractor
- remove plastic fan from hydrostat
- disconnect the electrical connector for the electric clutch
- from the top-side - use a 3/8" drive rachet - stick it into the tensioner slot next to the idler, rotate it to take tension off the belt, and remove belt off hydrostat pulley
- from underside - remove front idler (next to electric clutch)
- from underside - remove the "right-most" idler off the spring tensioner
- from underside - remove the "left-most" idler off the spring tensioner
- now the tensioner can rotate fully to take almost all the tension off the extension spring
- pop the spring off the tensioner arm
- the belt should now be able to be removed from the machine
- reinstall in the opposite fashion
- note: to reattach the spring, connect a nylon cord to the spring, and pull it rearward and guide it onto the tensioner arm - you need to stretch it about 1"
- for reattaching the two idler pulleys to the tensioner, get someone to hold the ratchet so the tensioner is positioned for the belt being in it's most-loose position. You may need to wrap the new belt around the hydrostat pulley first, and assemble the last idler pulley and belt at the same time to complete the procedure.
Apr 20, 2010 | Garden
How to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Oct 11, 2009 | Garden
My john deere 214 won't start
The deck lift lever normally wont start lifting until you pull back at least half way.Ther are 2 sets of wires that go under the fender deck,one set goes to the seat switch and the other set goes to the neutral start switch next to the shift lever,just in front of the seat.The neutral start switch wires more than likley came loose when you pulled fender deck off.The micro switch is on the back side of plate that surrounds shift lever.
Sep 03, 2009 | John Deere &Reg Branded 27" Tractor Metal...
Can't find model number
there should be a data plate somewhere on the tractor with model and ser #. Usually it is under the seat. The motor numbers are usually stamped on the engine cover with model type and code.
Aug 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Lexmark color printer, I can't find where the ink goes in?
if it's a flatbed scanner model, the whole scanner assembly on the top is larger than the printer portion below. if you lift up on the front corner of the larger scanner assembly, you will see the ink cartridge carriage tucked under the left or right far side when the printer is not printing. power the printer on, lift up the scanner assembly, and wait for the ink cartridge carriage to move itself out from being tucked off to the side. you will see a clip on the front top corner for each cartridge. gently pull forwards (the clip) with your thumb, and the cover will pop open to take out the old cartridge.
ps. remember to take of the piece of tape that covers the jet nozzels on the new cartridge before inserting cartridge into carriage.
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Husqvarna 23HP VTwin Hydrostatic 48" Cut Riding Mower Logo
83 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
